Results 1 to 3 of 3
- Sep 2006
- 16
May 10th, 2008 04:42 PM #1gurus ask ko lng poh why i feel this lack of power s arangkada para bng hindi kapit yung clutch ko.i replaced my clutch n pressureplate pro parang ganun pdin.di ako kontento sa hatak nya.my ride is 2003 starex.sa sctex nman npapatakbo ko sya ng 160km.sa arangkada lng parang kulang kapit.sabi nman mekaniko ko ok nman dw injection ko ksi sa andar plng dwe ng makina e very smooth nman daw.what do you think poh kaya problem?tenks po in advance!it will be a lot of help kasi gusto ko tlaga lumakas arangkada ride ko.
May 10th, 2008 10:01 PM #2
Starex ba? sakit ng Starex iyan, katulad nung akin. Bring it to casa or calibration center para ipalinis mo ang turbo. For sure turbo ang culprit niyan.
D4Bh TCI ba ang engine mo?
May 11th, 2008 02:33 AM #3
Clutch, preasure plate so I assume this a manual tranny if not, this may sounds like the torque converter if the problem is only on the start up. Anyway, another possible problem too are could be the fuel filter is clogged, weak fuel pump or restricted catalytic converter. Have your good mechanic check those...rule of thumb, go with the cheapest first.
Yes, i do think so. Since it's based on the 4th-gen delica/space gear, which in turn shares some of...
Mitsubishi Philippines
