Quote Originally Posted by c64rbr
The clutch kit of my car was just replaced (clutch pad, release bearing & pressure plate). After a week, the car began showing abnormalities. The engine shakes/vibrates violently while moving the car from stop in first gear as the clutch pedal is being released (clutch being engaged). The engine vibration is so violent that it shakes the entire car body. Ano po kayang problema nito?
The vibration doesn't happen when in reverse gear.
I appreciate any opinion before I return the car to the mechanic.
Pareho tayo ng problema. My theory is that the clutch does not sit properly on the pressure plate (there is a portion on the contact area of the disc/pressure plate that is closer to each other, which causes the vibration when you are releasing the clutch).
I just leave it there and let it seat after using them for a while. Nababawasan na yung vibration as I use my car.
that's just for me.
GoodLuck.
