Results 1 to 14 of 14
    May 2012
    Hi guys
    Nagvivibrate yung kotse ko while on idle (Civic FD) - sure na engine support problem ba ito? Usually anong side nasisira? And saan kaya best kumuha ng parts (and what's the reasonable price)? Is it ok to use non-OEM?
    I will have this checked sa talyer muna but any tips from the experts here regarding this issue?
    Thank you
    Quote Originally Posted by Renzokuken View Post
    Hi guys
    Thank you
    Sure na sure passenger side ng engine support alam na mga mekaniko yan sakit talaga ng FD. Yes ok lang replacement part ganun din yan less than 2k lang yan baka 1.5k lang yan engine support
    Mar 2004
    If you can afford, replace all engine / transmission supports at the same time ... use original they have better rubber albeit more expensive ...
    May 2012
    San ok bumili at that price? May alam ka bang murang bilihan tapos nagkakabit na din sila?
    May 2012
    Is there a huge risk if I only replace what's damaged/broken (i.e 1 side only)?
    personally,
    if the mechanic says only one needs replacement,
    then i'd have only that one, replaced.
    it's not like a car's ball joints, wherein the car has to be aligned after every replacement of just one part.
    Nope. Just replace the passenger side
    Jun 2011
    Sabi sa akin dati kung kaya ny budget, maganda palitan lahat ng same kind.
    Para same ang condition lahat ng rubber at balanced ang distribution ng vibration.
    Kung isa lang, iyong newest ang sasalo ng vibration kasi ito pinaka pliant, iyong iba malutong na.
    Quote Originally Posted by bxr monkey View Post
    i wonder,
    how many times will that one mount need to be replaced, before the other one shows signs of needing replacement?
    i wonder,
    As I heard from a Civic FD before, yung mga engine mounts bumibigay every 40k km. Baka malas lang sya.
    after many years, one would expect by now, that a more robust replacement would have been available in the market...
    May 2016
    Bought a replacement Toki brand from Northwest Auto supply along Shaw, near Starmall. That lasted until the second owner if I recall. Vibrations are more noticeable but better than a collapsed oem support.
    May 2021
    Hi guys
    Thank you
    oem pa dn, pricey pero sure na magtatagal.
    Quote Originally Posted by jaja01 View Post
    Hinde ka nagtatagal OEM na engine support ng FD eh.
Vibrations on Idle - Civic FD
