Results 1 to 11 of 11
    Oct 2005
    good day mga tsikoteers! newbie po ako and i have a 98 corolla. problem ko is minsan ayaw pumasok sa gear pag shift ko di ko po alam bakit ganun.please advice what to check.thanks!
    Please search po.
    Sep 2004
    Manual or AT?
    Kung manual, baka may leak na sa wellpan mo (don't know the proper spelling, pero that's what I heard from the mechanic who fixed it), kaya tumagas yung clutch fluid. Happened to our company Revo once, couldn't shift it to any gear, parang naka-semento, ayaw talaga gumalaw.
    Turns out na may nabutas lang na O-Ring, eh nasa Famy, Laguna kami nun. Kala ko I would be stranded. Dang part only cost 60 pesos, paid 250 for labor, and I was on my way.
    Aug 2006
    need more info...
    Oct 2005
    MT po yung corolla.nag momove naman yung kambyo actually pero paminsan minsan ayaw pumasok halimbawa nasa 3rd gear ako tapos shift to 4th hindi kumakagat tapos pag try ko ulit papasok na.minsan naman walang problem ang shifting.ganun din pag downshift.
    damaged synchro?
    Aug 2004
    Either it's time to change your gear oil or your synchros are worn out.
    Nov 2003
    probably either the clutch master or slave is the problem... pero hard to say without seeing it.
    May 2005
    Best way is to have it brought to a mechanic, dami kc pwdeng problem like yung slave, or yung synchro, pwede din yung clutch. Alam ko may thread dito detailing the symptoms and possible probs and diagnosis. You can try to search.
    Baka synchronizer!
    Oct 2005
    ok salamat po mga tsikoteers sa inputs.try ko dalhin sa mechanic within the week.salamat ulit!
transmission problem
