Page 1 of 2 12 LastLast
Results 1 to 20 of 23
    Feb 2006
    hi all,
    tranny here means transmission right? and not transvestite? LOL!!
    seriously now, hehe sorry, couldnt help it...., I have seen lots of posts stating "check your tranny" (for AT models)...and i would like to do that...
    assuming i bring it to a shop, what are the things they normally check for in the tranny?
    i think i have problems with my 1994 AT civic, (mileage is 85k) since i dont recall any maintenance being done on it in years....
    thanks!
    Jun 2006
    ATF is normally pinkish or red in color. If it smells burnt, replace it asap with the correct type of fluid. ATF is usually replaced every 2 years or 40,000 kms. Some people change at 20,000 kms. Check your manual as your cars replacement interval may be different.
    Things that you should NEVER do on an AT:
    1. Glide or rolling on neutral - can cause damage to the transmission.
    2. Shift from P or N to any gear without steping on the brake. This can cause the car to jump/jerk and hit something.
    3. Push start the car. This will not work you need to jump start.
    4. Drive without ATF unless you want to buy a new tranny. Hey I have personally seen this with a brand new Navigator, factory did not put fluid.
    I'm sure there are others just can't think of them right now.
    Things you should and can do to to an AT:
    1. Drive smoothly and treat the accelerator pedal like its an egg that you don't want to squash. This will help improve your fuel consumption.
    2. No. 1 can also make your car shift at lower rpms.
    3. Drive with OD on to save on gas. Think of the OD as a 4th or 5th gear.
    4. If you have economy or winter mode use it to save on fuel as you will up shift earlier.
    5. When climbing hills, you can turn off OD or downshift for more power.
    6. Downshifting can be done by moving the lever from D to 3 or by flooring the gas pedal.
    7. When going downhill, you can engine brake by turning of OD and downshifting.
    8. You can make your AT upshift by letting go of the accelerator pedal for a few seconds. This is easier done if you know what RPM it normally shifts.
    Apr 2006
    Quote Originally Posted by userfriendly View Post
    sir,
    paano masisira kapag nag-glide while in N, kasi ginagawa ko pa naman madalas yun. di ko kasi alam na nakakasira pala yun??
    how?? and ano ang masisira specifically?
    Jun 2006
    Sep 2004
    "Tranny"? Di ba ito yung asawa ni Lolo?
    One of the problems here, kahit sa Banawe, bibihira yung marunong talaga sa AT. Yung iba nga, di alam kung ano ibig sabihin ng shift solenoid or TCM, kung ano-ano pang sinasabi. Ang sarap bigwasan....
    Most gasoline service stations can only change ATF, tapos drain hole lang yung tatanggalin. They dont even dismantle the pan.
    uhm ok, since im hearing a lot og AT problems, any thoughts on my honda city i-dsi, sort of lifespan nya, im such a noob even bought the car kahit d pa ko sanay mag-drive last year, im also kinda scared asking this question... sana positive maging replies sa tanong ko, hehehe, TIA
    A transmission has no 'lifespan'. Just maintain it properly following manufacturer (not dealer) recommended maintenance procedures written in your owner's manual.
    The dealer's maintenance recommendations sometimes call for uneeded work (to generate themselves extra income).
    ah ok ok, thanks sir, i feel much better, hehe
    Ano bang difference ng power mode at OD off sa pajero field master? Sabi kasi sa manual use when you need extra power for overtaking and goin uphill. So for example paakyat ako baguio dapat ba sabay sila o isa lang at alin sa kanila ang isi switch?
    Quote Originally Posted by oliver1013 View Post
    the function of the overdrive (OD) button have been discussed extensively here in tsikot, please do a search.
    the power mode simply instructs the transmission to upshift at a higher rpm, which gives the car more power when overtaking.
    when going up baguio, putting your shifter at position D is enough.
    Ironically, you turn OD off when you need extra power for overtaking ang doing uphill. Confusing? Just check the other threads. hehehe.
    Basta O/D, up to 4th gear
    O/D off, up to 3rd gear only.
    Power mode is as defined by boybi
    HOLD - holds on to gears longer to avoid 'gear hunting' on long ascents/descents.
    Jun 2005
    *mudspit, you will learn a lot here about practically any problem under the sun and not just about your ride. There are a lot of experts who are willing to share their knowledge and experiences. Very informative! You can do a lot of DIYs if you're up to it.
    Quote Originally Posted by Hayward View Post
    yeah, i did and still learning, 'learned a lot of DIY's for minor detailing, as for mechanical/electrical issues, im still kinda scared to try... soon enough, i guess
    Nov 2003
    Quote Originally Posted by mudspit View Post
    If you don't mind getting grease, oil or dirt on your hands you'll surely learn alot.
    May be out of topic but I don't let the friendly "gasoline boy" check my oil, coolant and other fluid levels, not even tire pressure. Checking is done before leaving home especially on long trips. Top up everything that needs topping up. Don't pop that hood at the service station unless you really need to.
    Feb 2006
    Thanks for the advice guys! very helpful...
    i didnt know there were so many DON'Ts for ATs...I would always shift from D to N while the car was running at moderate speeds....hehe
    another question.....when you change the tranny oil does it have a filter that also requires replacement? (for the 94 Esi Civic)
    or is it just a matter or draining and re-filling?
    Jul 2005
    it does have transmission oil filter too.
    periodic change/ flushing of atf needs to replace the filter too.
    The ATF filter is usually a metal screen. It requires periodic cleaning. There are also magnets in the ATF pan which require cleaning.
    Nov 2003
    [QUOTE=OTEP;636696]...usually a metal screen. [QUOTE]
    If only Ford use the same for their suvs/trucks!
    Unfortunately for tsikoteers who have Ford XPs & F150s that share the same tranny (4r70w) the filter has to be replaced. It's paper type ("felt paper" not really sure how they call it) disposable & costly at P4K plus when I replaced mine over 2yrs. now. One thing I like is, the torque converter has a drain plug, but weird, the tranny's oil pan does not, so it's always "drop pan" and it's messy! But you get to replace over 90% of the atf, mercon V.
    Jun 2006
    [QUOTE=Jayo;636768][QUOTE=OTEP;636696]...usually a metal screen.
    It might be costly to replace the filter, but its cheaper than replacing the tranny.
    tutal tranny faqs na rin usapan... diba pwede palit transmission from a/t to m/t? and may idea b kyo magkano surplus na m/t pang civic and labor?
Tranny ..FAQs....
