Results 1 to 5 of 5
- Nov 2002
- 25
July 31st, 2003 11:54 AM #2
if you are referring to the bushing at the base of the shift-stick, normally dalawa lang ang bushing dun, they are plastic bushings.
Paki correct na lang po kung mali.
July 31st, 2003 04:22 PM #3Originally posted by artpogi
correct.
August 1st, 2003 12:22 AM #4Originally posted by artpogi
hard plastic ang OEM, polyurethane sakin nung nag palit ako ng short-shifter. shifter bushing nga ba talaga ang pinaguusapan natin?! hehehe.
this bushing?well, WRX bushing, hehe.
August 1st, 2003 12:26 AM #5
by the way, dalawa ang bushings or two-piece ang bushing?
Two-piece bushing but actually considered as ONE having it installed on the same location with the lever in between them.
mazda protege bushing
i have a theory, if the oil filter is not primed (filed up prior to installation), the initial...
Thick (20W-50) vs Thin (5W-20) Engine Oil Tested
