Results 1 to 17 of 17
    Aug 2007
    gud day po mga sir!
    i have this problem with my isuzu bighorn/trooper 95 model a/t tansmission. pag mag reverse ako d iilaw yung "R" sa speedometer tsaka d iilaw yung back light ko. pero paminsan minsan bumabalik din. d kaya loose contact to? But aatras naman yung sasakyan kaso nga lang d rin gagana backlight. any comments? thanks
    May 2007
    Quote Originally Posted by janrye26 View Post
    gud day po mga sir!
    Check your reverse light connection for rust and contaminant including your transmission sending unit (sending unit is next to transmission you have to go under the vehicle to check this) maybe loose.
    Aug 2007
    thanks po. will try
    Aug 2007
    yung sender nga ang problema. meron ba nabibili nito?
    May 2007
    Dealership. I dont how much pero, do it the first time.
    Aug 2007
    sana d cya kamahalan. tsk tsk tsk!
    May 2007
    Try to find out the problem baka loose lang ang wire connection dahil sa katatalbog ng sasakyan mo sa kalsada, or nag off road ka o di kaya ipinasok mo ang sasakyan sa mga matataas na weeds at nasabit yong wire kaya nag loose. Check it again.
    Aug 2007
    Quote Originally Posted by v6dreamer View Post
    pina check ko na po sa mekaniko. wala po naman daw problema sa ilalim but d po nila talaga binuksan ilalim. tiningnan lang po nla. d po ba electrician titingin nito?
    Jul 2003
    marunong ba naman sa A/T yung mekaniko mo? baka di siya pamilyar sa ganyang transmission.
    May 2007
    If your vehicle has a manual trany its just a simple switch located outside the tranny and if is a A/T make sure that they dont confuse w/ the transmission control module, do not let theme touch this "very expensive". Bring your car to your dealership or ask the diagram where the switch located since tranny switch are held in diff. location, some are located under the shifter linkage.
    Aug 2007
    plano ko nalang talaga po punta sa isuzu cdo. yun lang pinakamalapit sa amin. but will try all ur suggestions. salamat po talaga for helping
    Aug 2007
    auto transmission po akin sir
    Aug 2007
    ok na po transmission ko...
    how was it fixed?
    Aug 2007
    pinalitan ng sender
    May 2007
    I know you could fix it.:thumbup:
    Aug 2007
    salamat po.
transmission
