Results 1 to 10 of 17
Threaded View
- Nov 2015
- 5
November 15th, 2015 05:31 PM #15Hi. Need advice. Ung transmission ko kase may problem sa reverse. Delay ung response ng reverse shift tapos nung pinacheck ko ang problema daw is wiring dun sa inhibitor na nagcoconnect sa transmission ko. True po kya un? Ska magkano ba pagawa ng wiring?
That makes sense. Higher elevation has lower atmospheric pressure and even if the cooling system is...
