Results 1 to 10 of 37
- Dec 2003
- 35
January 12th, 2004 04:34 PM #1mga guys tanong ko lang po...what makes the diffence pag yung engine mo is using a timming chain rather than yung timming belt ..nung top overhaul ng 21R engine timing chain na gamit nito..pwede bang convert ang timming belt sa chain driven ..ano ba mas maganda?
January 12th, 2004 04:59 PM #2
Mas robust ang timing chain. It will not break as easily as a belt driven timing system. However, it is noisier esp. as it gets old and goes out of adjustment.
A timing belt will perform just as well as long as it is regularly maintained (replaced regularly). It will also be quiter.
January 12th, 2004 05:00 PM #3
It's like comparing metal to rubber. Ofcourse metal would probably last longer than rubber. But then again, you will have to live with claterring noise the chain makes. The best bet would have to be timing gears. But this is alot heavier than the two.
I doubt it if you could source parts for the idler arms and other internal parts when coverting it from belt to chain.
January 14th, 2004 03:55 AM #4
Yung bagong Pontiac Boneville, they are using a Timing Chain instead of the Timing Belt. Timing Chain is less prone to slippage specially sa 2004 models nila with 310ft-lb na torque.
Having said this, I think Timing Chain is more useful sa high HP autos. Timing Gear, di ba dito naka-kabit ang belt and or chain? So ang comparisons lang eh Timing Belt vs. Timing Chain kse they both uses timing gear, correct? Baka ang dapat nating compare sa Timing Gear is vs the Adjustable ones?!
Adjustable ones are for people who like to mod their engine [specially with an aftermarket cams, retainers n rings, internal engine], they can adjust the timing whenever they please or whenever they add another thing on the engine.
- Sep 2003
- 59
January 14th, 2004 09:18 AM #6
I have a timing chain equipped engine and hindi naman noticeable yung noise over its belt driven counterparts
diesel kasi e, inherently maingay
January 14th, 2004 12:13 PM #7
Originally posted by belcher
Karding, 3 types ang timing- merong belt, chain and gear. just
to be sure na na-gets mo ako kapatid....
timing chain and timing belt cannot be used to contrast with timing gear. Timing gear is a part of timing components [whether it be belt driven or chain driven,] correct? I know na may chain or belt driven. but both includes a gear, correct? Kaya ang sabi ko, hindi pwedeng compare/contrast and gear with belt and chain. we can only compare/contrast a similar parts of an engine.
technically, there are two types of timing element that drives the camshafts...chain and belt driven.
A timing gear is a part of those above mentioned parts.
January 14th, 2004 01:28 PM #8
May mga TD42 na timing gear ang gamit. Walang chain or belt, just interconnected sprockets. Na kay Ungas ang service manual. hehehehe.
Discontinued na yung gear driven kasi maingay.
January 14th, 2004 07:57 PM #9
Karding::: Yep may mga gears nga ang chain and belt driven engines. But there are other types of engine that the actual gears bite into one another. This has been proven to be much safer than the two combined. But as OTEP have posted, gear driven engines are almost at the brink of their extinction. Most machine shops advice to change the gears when the engine is being rebuilt. Not like timing belts that require change on 80-100K kms.
Btw, my TD42 engine is timing gear driven. :D
January 14th, 2004 09:10 PM #10
karding,
ikaw yata ang nalilito. explain ko ha wag pikon ok.
1. timing chain - may sprocket. hindi po yun gears, sprocket po yun.
2. timing belt - may cogged pulley. hindi din po yun gear, pulley po yun na may ipen para dun sa coggs sa belt.
3. timing gear - ay gear talaga. yan ang gear! meron po gear dun sa crankshaft, then may idler gear (pwede sa left o right pambaliktad ng ikot ng engine) tapos may intermediate gears para sa water pump, oil pump, tapos may gear yung camshaft.
advantage ng timing gear pwede mo baliktadin ikot ng engine, like kung gamit sa stern-drive speed boat na 2 ang engines at counter-rotation ang mga propellers. ililipat mo lang yung idler gear, add another gear for reverse rotation tapos reverse rotation na starter motor, baliktad na din rotation ng engine. aandar yung oil pump, water pump saka camshafts ng same direction pero yung crankshaft reverse ang rotation. yan ginagawa sa mga boat engines para counter-rotation ang propellers. o kaya naman gusto mo 5 speed ang reverse tapos 1 speed lang ang forward ng car pwede din hehe!
magbaklas po kayo ng c240 isuzu engine makikita nyo timing gear. o kaya naman detroit diesel engine gmv71. puro timing gears gamit dyan. may makikita kayo idler gear sa kanan. ilipat nyo yun sa kaliwang butas, may add ka isang gear sa isa pang butas tapos kabitan nyo ng starter motor na reverse, baliktad na ikot ng engine.
di yata pwede convert yung timing belt sa timing chain, oil lubricated kasi yung timing chain so pano mo i-lubrictae yun? e di tutulo yung oil di ba?Last edited by yebo; January 14th, 2004 at 09:14 PM.
Planning to buy a second car. Help me choose. Honda accord has 71k mileage for ₱465,000 Nissan...
honda accord 2014 2.4L vs nissan altima 2015
