Results 1 to 7 of 7
- Oct 2005
- 72
October 20th, 2006 10:40 AM #1Mga Bro ;
Need you help, last typhoon my car was soaked in flood, so iyong trany ko seems nahaluan ng tubig iyon loob but na drain ko na immediately at seems may konti pa rin natira when I checked so I done another drain and replace new oil... sa tingin nyo po ba may masisira agad sa loob. we know napakamahal mag paoverhaul at hindi pangaraniwan ang matic?
Please help.... thanks in advance
October 20th, 2006 12:55 PM #2
Pwede mo siya ipa-flush using a machine. Hanapin mo yung thread ng Autotechnika sa Goon Squad or use the search function for 'transtech'.
Around Php5,000.00 on average ang total cost for the service.
- Oct 2005
- 72
October 20th, 2006 01:41 PM #3Sir otep
Ang mahal pa la, .......
pag idrain ko lang every month mauubos din kaya iyon until mawala ang tubig? Or iyon tanong ko na makakasira ba agad ng transmission pag may halo konting tubig ?
October 20th, 2006 07:13 PM #4
Kung palitan mo iyan every month, ganun din ang gastos and hindi mo pa din makukuha yung fluid sa loob ng torque converter. Kahit palit ka ng palit ng oil, it will just get contaminated dahil may contaminated fluid pa din na natitira (assuming the system did get contaminated during the flood).
Transtech is Php900.00 for the labor, Php200/liter of ATF. Specify mo na lang how much ATF ang gusto mo ipang-flush if gusto mo makatipid ng konti. I think they will make you sign a waiver if you do it this way.
- Jun 2006
- 86
October 21st, 2006 02:31 AM #6same thing happened to me also.. ang ginawa namin is we left it draining for 8 hours.. then.. flushed it again and left it to drain for 4 hours....
tapos flush ulit.. tapos nilagyan na namin na atf.. ok naman sya.. wala namang sign or water or anything like that..
Tsikot Member Rank 5
- Nov 2003
- 3,849
October 21st, 2006 09:12 AM #7kung wala ka naman nararamdaman now na problem don't worry about it na.
high idle RPM at engine start
