Quote Originally Posted by ericbalajadia View Post
Uphill driving, could be that you haven't reached enough speed needed for the transmission to up-shift itself. Have it checked though just to be sure nothing is wrong with the transmission or engine.
Thank you po Sirs for replying. Hmmm let me double check my speed again when driving uphill. So what you guys are saying is, usually around 20 kp/h, my car supposedly should have automatically shifted gears already?
Pero from what i could remember, todo tapak na talaga sa gas pedal, it's impossible that i havent reached 20 kp/h.
usually naman pag naka bwelo sasakyan from flat tapos paakyat na okay na yung speed. pero living here in baguio, di maiwasan stop and go sa akyatan.
in any case, if indeed my gears aren't shifting when i reach 20 kp/h does that mean that the culprit is the transmission? im just wondering kasi pag FLAT road naman no problem with shifting from 1st/2nd/3rd... problem ko lang talaga is going UPHILL.
my friends are saying that that it could be the transmission already, since di nagshi shift. pero maybe i'm just really praying and hopeful na hindi, cause if that's the case then my wallet would surely be dead.hehehe
again thank you again mga papis. sorry i couldn't give you precise details to make it easier for you guys, noob lang talaga ako.
