Results 1 to 10 of 10
    Dec 2003
    Hindi maipasok sa 1st gear or any gear. I shut down the engine restart then ok na. What happened to my car kaya? 2x na to on a newly replaced clutch?
    have the primary clutch master checked.
    First of all, clutch will not be stuck in neutral, it should be your transmission gears that will get stuck. :D
    Baka po hydrovac assisted yung clutch nyo? It will need a little amount of air to push the clutch master if your ride has one installed. Kung cable type naman yan, malamang sa naipit yung cable.
    Dec 2003
    Thanks for the replies although, they're way to tech for me to understand.
    More details about this.
    My car is a 97 Mazda, recently just melted the release bearing for the clutch, took it to the shop and here's a list of stuff they replaced.
    pressure plate
    clutch disk
    release bearing
    flywheel bearing
    When I got the car back the immediate change I felt is super lambot yung clutch pedal, after a little driving to the office it happend downshift to number 2 ayaw pumasok, 3 & 1 din ayaw. Namatayan ako then when I restarted the car ayos. Happened a couple of times more pa.
    Here's my question can stffening the clutch pedal work? I'm thinking I'm not stepping on it deep enough? The other option is to take it back to the shop for another check, medyo hassle lang.
    Allow the clutch disc to blend in with your existing flywheel. Bago pa kasi yang mga parts kaya di pa ganun kalapat lahat. Check and test drive vehicle before leaving the shop, so that any minor adjustments can be easily done. What you can do is, ask if they know how to mark and restore the OE clutch settings, baka po kasi na-adjust na yung play ng clutch before.
    ah so downshifting ba bro?
    ganito lang yan:
    -kung mahirap ipasok yung gear when downshifting, baka *sychronizer gear* problem yan
    -kung mahirap ipasok ang gear to first gear from a full stop, malamang *primary clutch master*
    Goodluck!
    Dec 2003
    Thanks all. I will keep an eye on it, along with the mechanic of course.
    Jul 2003
    kung hydraulic operated ang clutch release ng otto mo, baka di na-i-bleed ng maayos nung mekaniko yung hydraulic line. my.02 lang po.
    Apr 2004
    adjustment lang yan dun sa clutch fork... bka mis align din yun end nun maindrive mo or, stuck up yun release bearing.. .have it opened and check up again pre...
    Nov 2003
    no need to open it up na. bleeding lang yan or baka kelangan ipaayos yung mga master
Clutch Got Stuck in Neutral
