First of all, clutch will not be stuck in neutral, it should be your transmission gears that will get stuck. :D
Baka po hydrovac assisted yung clutch nyo? It will need a little amount of air to push the clutch master if your ride has one installed. Kung cable type naman yan, malamang sa naipit yung cable.
Thanks for the replies although, they're way to tech for me to understand.
More details about this.
My car is a 97 Mazda, recently just melted the release bearing for the clutch, took it to the shop and here's a list of stuff they replaced.
pressure plate
clutch disk
release bearing
flywheel bearing
When I got the car back the immediate change I felt is super lambot yung clutch pedal, after a little driving to the office it happend downshift to number 2 ayaw pumasok, 3 & 1 din ayaw. Namatayan ako then when I restarted the car ayos. Happened a couple of times more pa.
Here's my question can stffening the clutch pedal work? I'm thinking I'm not stepping on it deep enough? The other option is to take it back to the shop for another check, medyo hassle lang.
Allow the clutch disc to blend in with your existing flywheel. Bago pa kasi yang mga parts kaya di pa ganun kalapat lahat. Check and test drive vehicle before leaving the shop, so that any minor adjustments can be easily done. What you can do is, ask if they know how to mark and restore the OE clutch settings, baka po kasi na-adjust na yung play ng clutch before.
adjustment lang yan dun sa clutch fork... bka mis align din yun end nun maindrive mo or, stuck up yun release bearing.. .have it opened and check up again pre...
