Results 1 to 8 of 8
    Apr 2004
    ewan ko kung ano nangyari... nagstart magfluctuate yun mazda ko ulit.... tapos namatayan... pero umaandar pa rin kasi pababa, tapos nagbrake ako tapos nilipat ko sa park pero gumgalaw pa ata... tapos tumunog... tapos inistart ko tapos okei na ulit... pero kanina, na-stuck ata sa neutral after mag3rd gear... matic yun car ko pero pag nag-3rd gear na siya (mararamdaman mo naman sa rpm eh) tapos kung babagal na ako eh biglang nag-flash yun HOLD tapos ayaw umandar or hirap umandar... umaabot ng 3000+ pero ang bagal mag-accelerate... twice nangyari sa akin from visayas ave to ateneo... pero pabalik okei naman... 2nd time pa lang ako naganito... ano kaya problem? na stuck sa neutral pagbaba ng gear?
    Mar 2004
    My friend also has the same problem with the transmission of his Opel Omega 2.5. Hope someone answers.
    Apr 2004
    bad trip talaga american cars...
    nag sli slip na ung clutch ng matic mo? ilan years na ba yan? try mo muna change atf,
    Apr 2004
    ah nag-slip na? kasi may nag-suggest rin sa akin nun eh... naubusan din kasi ng atf yun transmission kaya nun nilagyan ko naayos naman ng konti
    Apr 2004
    it happened to my new Pajero b4, 2 days out of the casa pa lang ayaw na run. It seemed it was stuck on neutral to. Then i had it towed sa Casa and they found out yun cables were off its place kaya i can't shift... bad trip... pero it was fixed then ok na. Chk your ATF level also like dbravo suggested...
    Feb 2004
    Sounds like your valves and clutch band servos are sticking. This is due mainly to contamination of the Hydraulic Fluid (ATF), but can also be caused by neglect and overheating.
    Sorry, but looks like your car's due for an a/t overhaul.
    Apr 2004
    bad trip... yup parating nag-overheat yun dati eh...
a/t pwede ba mastuck sa neutral?
