Results 1 to 6 of 6
    Jun 2006
    I have a cousin who owns a 1995 Honda ESI A/T. He refered to me the problem to w/c I cannot help. The shifting of gears from 1st gear to second gear changes at between 2.5 - 3.0 rpm. and from 2nd to 3rd at 3.0 rpm. medyo matagal. How could we solved the problem. New ATF has been installed. Do we need to replaced the transmission. Pls. Help Thanks
    Sep 2005
    same car po sa akin but never had that prob. may thread po akong nabasa dito about that A/T shifting prob pakihanap na lang po and if ever makita ko post ko dito. ung info na natatandaan ko pag madiin ka sa gas pedal matagal mag-shift ng gear.
    Nov 2003
    try having the throttle cable adjusted. if di na kaya then it might be that you're stepping on the gas pedal too hard.
    Aug 2006
    sa computer box puede rin adjust pero as much as possible do not tamper with the computer box
    Nov 2007
    baka naka over drive ang auto mo baka naka on ng OD??
    Jan 2011
    Yan ang matinding problema ng a/t transmission kaya aq ngmanual na dahil ang a/t pag nasira whole transmission palit..1 lang dahilan pwede nasunog ung oil seal kaya walang makapasok na oil sa tranny...or kaya ung transmission mo ay may low pressure kaya hindi matagal mgshift kailangan kase high pressure para mabilis magshift pwedeng ang tranny u may singaw ang cup..base on my experience nagkaroon aq matic..sakit sa ulo buong transmission baba then i find a surplus tsambahan pa makakita ng maayos...and wag kayo magpapagawa sa mga hindi automatic transmission expert..
A/T problem on 95 Honda ESI
