Results 1 to 6 of 6
- Jun 2006
- 4
June 19th, 2007 05:07 PM #1I have a cousin who owns a 1995 Honda ESI A/T. He refered to me the problem to w/c I cannot help. The shifting of gears from 1st gear to second gear changes at between 2.5 - 3.0 rpm. and from 2nd to 3rd at 3.0 rpm. medyo matagal. How could we solved the problem. New ATF has been installed. Do we need to replaced the transmission. Pls. Help Thanks
February 23rd, 2008 09:53 PM #2
same car po sa akin but never had that prob. may thread po akong nabasa dito about that A/T shifting prob pakihanap na lang po and if ever makita ko post ko dito. ung info na natatandaan ko pag madiin ka sa gas pedal matagal mag-shift ng gear.
Tsikot Member Rank 5
- Nov 2003
- 3,849
February 24th, 2008 11:53 AM #3try having the throttle cable adjusted. if di na kaya then it might be that you're stepping on the gas pedal too hard.
April 27th, 2008 09:17 AM #4
sa computer box puede rin adjust pero as much as possible do not tamper with the computer box
- Jan 2011
- 4
January 17th, 2011 03:11 PM #6Yan ang matinding problema ng a/t transmission kaya aq ngmanual na dahil ang a/t pag nasira whole transmission palit..1 lang dahilan pwede nasunog ung oil seal kaya walang makapasok na oil sa tranny...or kaya ung transmission mo ay may low pressure kaya hindi matagal mgshift kailangan kase high pressure para mabilis magshift pwedeng ang tranny u may singaw ang cup..base on my experience nagkaroon aq matic..sakit sa ulo buong transmission baba then i find a surplus tsambahan pa makakita ng maayos...and wag kayo magpapagawa sa mga hindi automatic transmission expert..
Xiaomi E-Car
