Results 1 to 9 of 9
    Jun 2007
    guys question naman. lately, napansin ko sa kotse ng father ko, pag nilalagay ko yung shift stick sa pagitan ng 1st and 2nd gear, hindi na siya bumabalik sa N position. should i worry? car is 2000 nissan sentra ex saloon exalta body, all stock. nagpalit ng clutch before. siguro 1-2 years ago na, pero less than a week palang nung lumabas yang ganyang condition ng kotse. help mga sir. hindi kasi ako sigurado kung kailangan ko mag-worry. TIA!
    Jun 2007
    up ko lang.. safe pa kaya gamitin yung kotse kahit na ganun na yung shift stick?
    Feb 2009
    Quote Originally Posted by jeDi13 View Post
    the shifter mechanism might be stuck from rust or dried up lubricant on the shift mechanism just outside the transaxle at the other end of the shifter cable. try spraying with silicone lubricant or a suitable equivalent
    When you shift gears,- the stick goes to the Neutral position first, right?
    Also, normally, the stick rests not in the 1-2 column but in the 3-4 column for "safety reasons".....
    9909:gotcha:
    Dec 2003
    Shifters have rubber bushings. They may be just worn. You can start eliminating possible reasons by checking those.
    Dec 2007
    Quote Originally Posted by RustyXIII View Post
    +1
    It's also worth checking the condition of the shift cables while you're at it.
    Jun 2007
    thanks guys. i'll take note of those things you've listed. hope it's just a minor problem though..
    by the way, sir CVT, what do you mean by:
    yes, when i shift gears, it's in the Neutral position first. since you've mentioned the 3-4 columns, problem with my dad's car is that the stick doesn't rest there. if you try to move it to the 1-2 position, it will not go back to 3-4 column. it will just rest at 1-2 colum. you have to manually move it again to 3-4 column.
    Jul 2003
    Your shifter problem is most probably caused by worn out shifter bushings which are located at the base of the shift stick. There is also a return or neutral positioning spring which normally does not need replacement. this is an easy part to replace if you have tools and technical know how. It can be safely replaced by the technician at the auto supply where you intend to get the shifter bushings.
    Apr 2010
    advise ko sir, pacheck mo sa transmission specialist na to...mura lang maningil at ieexplain sayo at bibigyan ka ng options...sabihin mo lang refer ka ni marvi...
    mang rey
    09308515383
    9373983
shift stick ayaw bumalik sa Neutral
