Results 1 to 9 of 9
May 24th, 2010 02:30 PM #1
guys question naman. lately, napansin ko sa kotse ng father ko, pag nilalagay ko yung shift stick sa pagitan ng 1st and 2nd gear, hindi na siya bumabalik sa N position. should i worry? car is 2000 nissan sentra ex saloon exalta body, all stock. nagpalit ng clutch before. siguro 1-2 years ago na, pero less than a week palang nung lumabas yang ganyang condition ng kotse. help mga sir. hindi kasi ako sigurado kung kailangan ko mag-worry. TIA!
May 24th, 2010 06:40 PM #2
up ko lang.. safe pa kaya gamitin yung kotse kahit na ganun na yung shift stick?
May 25th, 2010 06:41 AM #3
May 25th, 2010 08:02 AM #4
When you shift gears,- the stick goes to the Neutral position first, right?
Also, normally, the stick rests not in the 1-2 column but in the 3-4 column for "safety reasons".....
9909:gotcha:
- Dec 2003
- 137
May 25th, 2010 09:48 AM #5Shifters have rubber bushings. They may be just worn. You can start eliminating possible reasons by checking those.
May 25th, 2010 10:03 AM #6
May 26th, 2010 01:06 PM #7
thanks guys. i'll take note of those things you've listed. hope it's just a minor problem though..
by the way, sir CVT, what do you mean by:
yes, when i shift gears, it's in the Neutral position first. since you've mentioned the 3-4 columns, problem with my dad's car is that the stick doesn't rest there. if you try to move it to the 1-2 position, it will not go back to 3-4 column. it will just rest at 1-2 colum. you have to manually move it again to 3-4 column.
- Jul 2003
- 573
May 31st, 2010 05:15 PM #8Your shifter problem is most probably caused by worn out shifter bushings which are located at the base of the shift stick. There is also a return or neutral positioning spring which normally does not need replacement. this is an easy part to replace if you have tools and technical know how. It can be safely replaced by the technician at the auto supply where you intend to get the shifter bushings.
June 3rd, 2010 07:18 PM #9
