Results 1 to 6 of 6
    Jun 2009
    Mga sir OK lang ba kapag may transmission leak?
    ang sabi kasi sa akin ipaunder wash ko kaso hindo ko pa nagagawa eh..
    may disadvantages ba un transmission leak?
    Thanx!
    Feb 2009
    Quote Originally Posted by dubidubidu View Post
    Thanx!
    there are reasons why the leak is supposed to be repaired as soon as possible:
    1. the transmission might get too low in fluid without you knowing until it breaks
    2. the fluids will drip to the road or your garage and will cause tires or yourself to slip when the road or floor gets wet
    3. it pollutes the area where you stop or park your car
    4. when the vehicle is moving, all the fluid dripping gets sprayed to the rubber bushings of the suspension causing them to degrade or melt. please use good judgment
    May 2009
    as long as manual tranny mo, magiingay naman yan kapag kulang na fluid. malaking problema kung automatic yan bos dubi. sakin namamawis pero wala napatak ng malakas. monitored daily naman A/T ko sa fluid.
    Aug 2007
    so, paano kaya i-fix ang transmission leak para naman maalis yun mantcha ng leak (hindi tumutulo sa floor ng garage...)?
    May 2005
    Try checking the connection points of the hose that travel to and from the ATF canister. Usually the clip loosens or degrades over time.
    Apr 2010
    Quote Originally Posted by silver streak View Post
    advise ko sir, pacheck mo sa transmission specialist na to...mura lang maningil at ieexplain sayo at bibigyan ka ng options...tapos sya na maghahanap ng parts…hindi ka rin dadayain….mapagkakatiwalaan…wala syang shop pero sa house lang nila gagawin kaya walang charge sa pwesto…ung sakin iniwan ko ung sassakyan at wala naman nawala...aalagaan nya talaga yung tiwala ng customer…sabihin mo lang refer ka ni marvi...
    mang rey
    09308515383
    9373983
transmission leak.
