Results 1 to 6 of 6
- Sep 2011
- 3
September 11th, 2011 03:17 PM #1Mga boss..pa advice nmn before i buy a new tranny..the problem is ang hinda ng 1st gear at antagal magshift sa 2nd gear..kahit isagad mo ung gas pedal ayaw bumilis..nu kaya sira??electrical b?or whole tranny replacement na??
- Jun 2011
- 134
September 12th, 2011 09:41 AM #2Sir,invecs na ba ung lancer mo.pero kung ang problema eh ung matagal mag shift,check mo bka sobra or kulang ang ATF.or check ung adjustment ng throttle kick cable na papunta sa tranny.baka loose or mashado mahigpit ung adjustment.
- Jan 2009
- 8
September 12th, 2011 04:46 PM #3Try mo pa check kay Mr, alex or Leonard Bulaong sa banawe.They fixed my AT tranny and up to now working pa din sya.Highly recommended sa dito sa tsikot. Their nos is 7496586.
- Sep 2011
- 3
September 20th, 2011 10:46 PM #4di ko alam kung invecs n boss eh..basta carb type pa na pizza toh..ung atf naman is nasa gitna ng cold and hot level kapag ginamit na..3000rpm bago mag2nd gear tpos pag 3rd gear na bumabalik agad 2nd gear with in 1 second...why gnon?
- Sep 2011
- 3
September 20th, 2011 10:49 PM #5ai boss eto pa pala..kapag nakapark ung kotse..tumataas bumababa ung rpm niya..dba dapat steady lng sa 750 rpm db?ung oto is 750 tpos aakyat ng 1000 tpos bababa ulit..nu kaya un..matagal na kasi di nagamit eh.
September 21st, 2011 01:17 PM #6
pwede din sa makina ang problem at hindi sa tranny kasi sabi mo ang hina ng hatak (sagad na gas ayaw bumilis). di kasi magshi-shift yung tranny pag mababa ang torque kaya inaabot ng 3000rpm bago mag-shift to 2nd. possible causes could be clogged fuel filter, water in fuel, clogged carb nozzle, dirty air filters...
Though not on a people carrier like the Innova, I have Yokohama es32 equipped on my Sylphy since...
Finding the Best Tire for You
