Results 1 to 3 of 3
    Sep 2006
    gurus ask ko lng poh why i feel this lack of power s arangkada para bng hindi kapit yung clutch ko.i replaced my clutch n pressureplate pro parang ganun pdin.di ako kontento sa hatak nya.my ride is 2003 starex.sa sctex nman npapatakbo ko sya ng 160km.sa arangkada lng parang kulang kapit.sabi nman mekaniko ko ok nman dw injection ko ksi sa andar plng dwe ng makina e very smooth nman daw.what do you think poh kaya problem?tenks po in advance!it will be a lot of help kasi gusto ko tlaga lumakas arangkada ride ko.
    Aug 2007
    Starex ba? sakit ng Starex iyan, katulad nung akin. Bring it to casa or calibration center para ipalinis mo ang turbo. For sure turbo ang culprit niyan.
    D4Bh TCI ba ang engine mo?
    May 2007
    Quote Originally Posted by xenon View Post
    Clutch, preasure plate so I assume this a manual tranny if not, this may sounds like the torque converter if the problem is only on the start up. Anyway, another possible problem too are could be the fuel filter is clogged, weak fuel pump or restricted catalytic converter. Have your good mechanic check those...rule of thumb, go with the cheapest first.
what do you think clutch or injection pump???
