Sirs, need some help....
I have a strada 4x4 sport V (automatic). The gear stays at 2nd and 3rd gear only with the check engine light on.
This happens when you are running in high speed/high revs. Before this will happen, shock shift occurs. To remedy the problem, turn off the engine and restart.
Brought the unit to mitsubishi, they replaced the speed sensor twice, same problem occurs. Need help.
Thank you
