Results 11 to 12 of 12
August 17th, 2004 01:43 PM #11
I 'm also having the same problem right now. Parang may squeek na ngumingiyaw na di mo maintindihan. I tried spraying penetrating oil but may natira pa rin konting squeak. Does the rainy season might have something to do with this?
August 17th, 2004 03:59 PM #12
overhaul the clutch system? or just overhaul lang the clutch cylinder?
high idle RPM at engine start
