Results 1 to 10 of 10
- Nov 2006
- 45
November 24th, 2012 03:24 PM #1hi guys, magkano po ba labor ng pagbaba ng transmission? slide na kasi clutch lining ko.. btw, toyota 4k engine lang ito mga sir. magkano din po magpa bonding ng clutch lining?
salamat po...
November 26th, 2012 05:52 PM #2
dunno with your car, but when i changed the clutch of my 07 getz two months ago, it cost me around 8k..
labor and parts included.
- Nov 2006
- 45
November 26th, 2012 06:42 PM #3that's really costly i think.. whew.. need enough budget for that. may i ask if you completely change the whole thing, i mean the clutch lining itself? or you just rebond it..
thank you...
- Jul 2006
- 61
November 26th, 2012 07:11 PM #5no one bonds their clutch these days.
not unless pampasada yung ginagamit nyo.
labor is around 2.5k and the kit (clutch disc, pressure plate, release bearing) probably around another 4k.
- Nov 2006
- 45
November 28th, 2012 05:50 PM #6so 4k would be the budget... whew.. thats alot of money for a 4k engine.... thanks guys... need funds for it.. hope by january... well im still using my vehicle just running 40kph - 50kph so that clutch sliding will not too noticeable...
- Nov 2006
- 45
December 1st, 2012 09:24 PM #7sobrang disappointed ngayong araw. pinababa ko transmission ko para palit clutch lining, nung nababa sabi ng mekaniko sobrang kapal pa daw at d pa umabot don sa revits ba tawag don... lalim pa ng reviits... sabi saken baka yung bering dahilan, ayun bumili ako 550pesos, pagkabit na... ganun pa din... 2200 gastos ko lahat... sobrang nakakainis... kapal pa rin tlga lining ko.. nakita ko din naman kasi... sayang pera ... hayzz... bakit kaya sliding ito mga sir?
- May 2006
- 913
December 2nd, 2012 09:51 AM #8baka naman sir you have a problem sa pedals lang.. just in case its not releasing totally..
- Nov 2006
- 45
- Jun 2014
- 21
August 5th, 2015 12:30 PM #10
high idle RPM at engine start
