Results 1 to 10 of 10
    Nov 2006
    hi guys, magkano po ba labor ng pagbaba ng transmission? slide na kasi clutch lining ko.. btw, toyota 4k engine lang ito mga sir. magkano din po magpa bonding ng clutch lining?
    salamat po...
    dunno with your car, but when i changed the clutch of my 07 getz two months ago, it cost me around 8k..
    labor and parts included.
    Nov 2006
    that's really costly i think.. whew.. need enough budget for that. may i ask if you completely change the whole thing, i mean the clutch lining itself? or you just rebond it..
    thank you...
    Nov 2004
    Around 2k-3.5k usually ang labor
    Jul 2006
    no one bonds their clutch these days.
    not unless pampasada yung ginagamit nyo.
    labor is around 2.5k and the kit (clutch disc, pressure plate, release bearing) probably around another 4k.
    Nov 2006
    so 4k would be the budget... whew.. thats alot of money for a 4k engine.... thanks guys... need funds for it.. hope by january... well im still using my vehicle just running 40kph - 50kph so that clutch sliding will not too noticeable...
    Nov 2006
    sobrang disappointed ngayong araw. pinababa ko transmission ko para palit clutch lining, nung nababa sabi ng mekaniko sobrang kapal pa daw at d pa umabot don sa revits ba tawag don... lalim pa ng reviits... sabi saken baka yung bering dahilan, ayun bumili ako 550pesos, pagkabit na... ganun pa din... 2200 gastos ko lahat... sobrang nakakainis... kapal pa rin tlga lining ko.. nakita ko din naman kasi... sayang pera ... hayzz... bakit kaya sliding ito mga sir?
    baka naman sir you have a problem sa pedals lang.. just in case its not releasing totally..
    Nov 2006
    i will check for that sir.. salamat po...
    Jun 2014
    Quote Originally Posted by exoskeleton View Post
    Baka adjustment lang yan sa cable ng clutch.
sliding clutch lining
