Results 1 to 10 of 17
- 71
March 27th, 2003 04:43 PM #1before, when trying to accelerate in a high gear, hirap yung engine... plus may knocking sound from the engine.
lately, kahit high gear, wala nang knocking sound. para na syang automatic, nakahigh-rev tapos onti onting bumibilis yung takbo.
sinubukan ko na yung test na pinost dati dito on checking for a slipping clutch. yun yung nakaengage yung handbrake, then release clutch. namamatay naman yung engine ko.
sooo, what do you think? is my clutch slipping already?
- 82
March 28th, 2003 11:22 AM #3
usually ayaw ng humatak pag sliding na clutch mo tapos yung nga meron na rin knocking sound sa engine kasi tumotope na makina mo, ramdam mo yan pag-paahon ka, pa-check mo na sa iyong suking mekaniko8)8)8)8)8)8)8)8)8)8)8)
- Dec 2002
- 375
March 29th, 2003 06:30 PM #4when you step on the gas parang hindi instantaneous yung acceleration like before.
in worst case you can stop your car in gear w/o stepping on the clutch and you engine will still be running
- Dec 2002
- 39
April 1st, 2003 08:36 PM #5tikboy, per your premise, hindi outright na clutch ang problema mo. I think may problem ka sa timing ng engine mo. start problem isolation with
tune-up of engine. pag lean kasi masyado timing mo, medyo mahina arangkada sa high gear. kung carb yung engine mo, i-choke mo para malinisan, or use carb cleaner. this is to ensure na ok ang fuel system mo. post mo uli results.
- Mar 2003
- 91
April 4th, 2003 04:44 PM #6pre! if gsto niyo malaman kung sliding na mga clutch ng auto ninyo...
lagay niyo sa 4th gear if hindi siya nag jolt forward it's worn out already
basta dapat mag umabante ang auto...
April 5th, 2003 07:46 AM #7
magkakano ang aftermarket clutch and which one will you recommend? ung street/strip use lang nde full race...:roll::roll:
April 5th, 2003 11:13 PM #8
update ko lang po itong thread. Ung clutch ko kasi may krrrrrrrrrrrrrrrkkkk sound kapag biglang nirerelease ung clutch pedal. pero pag inapakan ulit mawawala. May mga instances lang naman and ok naman ang gear shifting ko. Ano kaya culprit?
How much ba ang mga prices ng clutch parts? Para may idea lang ako. Thanks!!!:|
April 5th, 2003 11:17 PM #9
add ko lang po:
Ung pag shift ko into a higher gear, hindi naman naka high rev (always) and mabagal ang acceleration. Naririnig ko ang gradual increase sa revving ng truck ko before the actual acceleration or arangkada so this means hindi pa ko sliding...am i right? :mrgreen:
Annoying lang talaga ung kumukurokok paminsan minsan
April 6th, 2003 01:38 AM #10
ako naramdaman ko na sliding yung dati kong car ng paahon ako na nasa third gear puro ayaw ng humatak car sagad na rev ko ayaw pa din mahina buti na lang isa lang sakay ko kundi di aahon, don pa naman ako sa bulubundukin ng san pedro
Gamet ko cone filter kapag ba malakas Yung higop Ng hangin servo motor na tlaga sir
LANCER Itlog (93-96) Owners - Please Post Here!
