Results 11 to 17 of 17
- Mar 2003
- 91
April 6th, 2003 05:49 PM #11B16ba-type-RSiR,
recommended ng mga ibang tao sa civic nila spoon organic clutch coupld w/exedy pressure plate
it can handle high power tlga with stock feel ang clutch pedal not
sure lang how much ito...
basta if you want to check tlga kung sliding ang clutch ng mga auto put it on 4th gear
tpos pag hindi nag jolt forward it means worn out na tlga clutches ninyo..
bout nman dun sa "krrkkk" sound na yun...what's your car ba? bka nman cable type ang iyong clutch so you need to lubricate the cables lang..para mawala ung "krrkk" kse ang mga lumang model ng cars nka cable type clutches eh..newer models nman like the
civic SiR's nka hydraulic type clucth na..so yun lang...hehe:D
April 6th, 2003 11:57 PM #12
My truck is a mitsu L200 pickup. Hydraulic clutch na po ito..
Anyway, napa-check ko kanina and the mechanic said that its still a-ok! Ung clutch pedal ko lang daw ang maluwag. :mrgreen:
- Mar 2003
- 91
April 7th, 2003 07:19 PM #14B16ba-type-RSiR,
nakapag palit ka na ng clutch?? and nga pla di lalaklak ng gaso auto ni Djerms diesel yun eh hehe..
Djerms,
paayos mo nlang din para tipid crude cnsumption...
April 18th, 2003 11:07 AM #15
ganyan din ang L3 ko ngayon, kapag primera and segunda mahirap ipasok ang kambyo, tapos kapag umatras ako minsan may kurororokk din... di kaya dahil ma"wego" ang kambyo ko? di ko pa nasubukan yung 4th gear tapos paandarin, try ko mamaya and balitaan ko kayo
April 21st, 2003 07:32 AM #16
Mga Sir,
Ung sakin naman kasi kapag neutral ko lang naririnig ang tunog. Parang may maluwag lang na screw. Napaayos na po, dun daw sa clutch pedal ang culprit :mrgreen:
I also tried releasing the clutch at 4th gear at napakalakas pa ng pag-jerk so i guess hindi pa po ito sliding. A good shop is found in marikina, near SSS village according to a friend. :mrgreen:
- Sep 2008
- 35
November 3rd, 2011 06:12 PM #17
high idle RPM at engine start
