Results 1 to 3 of 3
    Dear Tsikoteers with A/T ride,
    My mechanic said that the sensor (solenoid assy, electronic daw ito) in my 2002 xwind A/T is no longer responsive that causes shift delays. ATF and trans assembly is A ok hence he conclude that the sensor is defective. Called isuzu pasig pero wala available stock and cost about P9K.
    Meron ba kayo alam na shop outside of the isuzu chain that carry original or replacement parts? Pls advise. Thanks.
    Oct 2004
    try to check the atf level first, if its low it may cause the delay in shifting. If its ok naman change your atf, I doubt that its a faulty sensor, if everything else fails then thats the time to change your sensor.Try the less costing measures first before jumping on the expensive ones. goodluck
    Quote Originally Posted by bratski View Post
    Yes Bro done na all basic pms for a/t.
shift sensor for automamtic trans - xwind
