Results 1 to 2 of 2
September 30th, 2009 07:26 PM #1
Hi!
I just wanted to ask what could be causing a revving sound on my 2004 kia sedona A/T.
Pag sa subdivision namin (maraming humps) during the initial acceleration mararamdaman ko yung pag-shift nya to second gear walang problema pero suddenly may sound na parang "rrrrrrrmmmmm.....!" na para kang nagre-rev. Mga 2-3 seconds lang sya tapos back to normal na.
Kahit sa skyway during the initial acceleration minsan nararamdaman ko yun.
I'm thinking nag-shift sya sa second gear pero dahil bitin, babalik sya sa first gear.
Ano po sa tingin nyo?
I just had a tune-up done at Muntinlupa Kia Motors about 2-3 weeks ago, wala naman silang sinabing problem sa engine or sa transmission. Bagong palit lang ang engine oil. Ang transmission fluid sa 45k pa daw ang palit (nasa 39k pa lang sya ngayon).
TIA!
October 1st, 2009 09:10 PM #2
since 6k kms na lang ang difference, i would suggest having the ATF replaced first. most probably, dun pa lang, baka maayos na yun. baka kasi degraded na.
For the Toyota products its likely to be the case for most of their products per the service...
Wheel Alignment
