Results 1 to 20 of 53
    overdrive is used on highspeeds. parang ito yung nag enable and mag disable ng 4th gear or last gear sa mga AT.
    dapat ang overdrive or OD is laging naka on para tipid sa gas.
    IMO OD has noting to do with engine breaking. sobrang bilis naman kung engine break ng 3rd gear.
    :peace:
    Dec 2007
    Quote Originally Posted by s_quilicot View Post
    :peace:
    No one said anything about using OD for engine BRAKING (not breaking) before this post of yours, dude.
    Jan 2009
    I find it weird that Toyota would put L and 2 and advice drivers not to use them. Why will the A/T overheat? Don't they have a lock-up clutch?
    Dec 2007
    Sorry, I forgot the important part: FOR EXTENDED PERIODS ("for a long time" in the manual). My bad.
    Here's the mentioned page, by the way:
    Jan 2009
    ^ Thanks for that. Still is weird that their A/T can't cope with that. Should I assume that they really don't employ a lock-up clutch? To the uninitiated, the lock-up clutch holds the two sides of the torque converter together under specific conditions. This is so that there's no torque loss due to fluid coupling and generally little to no heat is generated.
    I would love to see the specs on the Avanza tranny.
    Dec 2007
    I think it would have been better if they specified how long is "too long."
    Is this what you're looking for?
    Sep 2005
    dont forget to turn OD off when using L or 2.
Questions regarding A/T- D, 2, L?
