Results 1 to 10 of 20
July 2nd, 2005 02:25 AM #1
The Car - 95 lancer glxi a/t
The Problem - while driving at nag-full stop ka, then u press the gas to accelerate, it will take mga 15-30 seconds bago umarangkada ulit yung car kahit di mo inaalis sa "D" yung gear...
it happened to my friend's car kanina lang.. kaya yung 6 km trip namin kanina, inabot ng mahigit 30 minutes... traffic pa kasi..
ano kaya problema at solusyon nito?
- Jun 2005
- 113
Tsikot Member Rank 5
- Nov 2003
- 3,849
July 3rd, 2005 03:46 PM #5
u might be low on atf fluid, or worse u could have a leak causing low atf
- Jun 2005
- 113
July 3rd, 2005 05:57 PM #6Check Automatic Transmission Fluid (ATF) level first, before considering other possibilities.
Follow manufacturer's recommended procedure for checking the ATF level. Most prescribe idling the engine at normal temperature, transmission in N, level should be in between the MIN and MAX marks.
July 3rd, 2005 11:56 PM #7
Low-ATF ang culprit when that happened to me.
- Nov 2003
- 3,849
July 5th, 2005 12:11 AM #8check the dipstick. if puno, have the drainplug (normally magnetic) checked. kung marami na nakakapit na metal flakes then that's bad news.
July 5th, 2005 03:29 AM #9
thanks for all ur inputs.. i will relay to him all your advices. di na nga nya gamit car kanina kasi it's causing traffic daw... hehehe... nagtanong na din daw sya sa mechanic though di nya dala yung car.. worst case scenario is change tranny daw.. ano ba mas mainam: to overhaul, buy surplus A/T tranny or change to surplus manual tranny na lang... and magkano magagastos..
- Nov 2003
- 3,849
July 5th, 2005 10:11 AM #10di ka sigurado sa overhaul. mas mahirap pa overhaul ng tranny kaysa sa overhaul ng makina. hehe!
get the surplus matic. it will be the cheapest. dami ka pa coconvert kung kukuha ka manual...
Apparently, that's turning out to be a rather small crowd.
