Aandar ba ang sasakyan kapag nasa Drive or Reverse pero hindi nakaapak sa brake pero naka handbrake?
When the handbrake (manual or electronic) is engaged, the car will not move forward or backward. However if the manual handbrake was engaged only slightly (first click on pull) and you floor the gas pedal, the vehicle will surge forward/backward and you're in for big trouble already.![]()
Next question siguro. Aandar ba kotse pag Walang gasolina
*Sayu
You need to enroll sa driving school para may formal teaching.
Aside sa driving para familiarize ka din sa rules / signs / markings
Illogical kasi yung tanong, bakit mo i-engage ang handbrake and move the car at the same time?
To answer if sagad handbrake hindi yan aandar.
Pero if aapak ka sa accelerator, chances are it will move pa din.
You drive naman pala, minor adjustment na lang yan or totally wala since accelerator and brake lang aapakan mo.
Basically
From Park to reverse/drive apak muna sa brake
Never coast on neutral.
Pag saglit na stop stay on drive while apak sa brake
Pag long stop you can neutral then apak sa brakes / engage handbrake
Avoid putting it on P unless you are about to park na talaga.
hi, i just got a Fortuner Dsl A/T after driving a Revo Gas M/T for at least 18 years.
so, when i come to a stoplight and it's more than a minute, i put it in N and handbrake. or, leave it in D, and use the handbrake.
which is a better or acceptable practice?
i'm a bit skeptical bout the lifespan of A/T and the cost to repair if there's an issue na.
thanks!
thanks for the replies. i feel better knowing di lang ako gumagawa nyan.
youre going to eat the rear hand brake. especially with a diesel engine
I don't think the reason is baka malagay mo sa reverse, kase daanan mo pa rin naman R then N bago D. The plain reason why you should not put it to P during traffic is you are not actually really parking?
