Results 21 to 30 of 57
- 3,754
November 8th, 2005 09:17 AM #21Originally Posted by gearspeed
I got funny experience sa A/T... sa tagal ko naka idle sa parking ng pinatay ko engine nasa N pala hindi ko ma tanggal ang susi.. atmost 30mins pinipilit ko alisin hhahahaha buti na pansin ko nasa N pala dapat sa P...
November 8th, 2005 09:25 AM #22
hmmm, imho. 30 minutes parking with engine running? kung ako yan, papatayin ko na lang makina and magaabang na lang ako somewhere else. sayang gas.
November 9th, 2005 03:51 PM #23Originally Posted by happy_gilmore
- Sep 2005
- 40
November 10th, 2005 09:35 AM #24hello!
for the info lang.This is what I've read in the auto tranny manual for mitsubishi only(W4A33 transmission)..don't know with others......
Pag naka "P" ka ung atf hindi dumadaan sa aux. system cooler,pero pag "N" dumadaan ung fluid sa cooler.Usually pag start sa umaga,naka "P" para ma heat up to operating temp ung ATF before driving.
proven na ito because I installed a thermometer gauge sa ride ko para mamonitor ko ung temp ng ATF.malalaman mo rin kung nag ooverheat ung fluid before hand to prevent tranny failure.Normal operating temp of ATF is between 50-85'C.Most tranny fail after fluid overheating.
so My advice is when idling for long period,better to put in "N" pos and "P" only before stoping your engine.
Important thing also is never put any ATF to your ride unless it meets the manufacturers specification.Shifting points & clamping pressure of bands inside will vary with the type of fluid used.
hope this helps. HAPPY SHIFTING................
November 10th, 2005 10:10 AM #25
sulzer, what is your transmission temperature gauge? is it one designed solely for a/ts or is it just a typical temp gauge? how did you install it? tia.
- Aug 2003
- 91
November 10th, 2005 10:43 AM #27Originally Posted by pentot2
Oh and one more, don't ever leave the tranny in drive when stopping coz' it will heat up the torque converter especially on hot climates like here in pinas.
- Sep 2005
- 40
November 10th, 2005 01:32 PM #28Originally Posted by diesoline
Its an electrical resistant type gauge not a conventional capillary tube type na mabibili mo na mura.Auto Gauge ang tatak(cost 1900 pesos,complete kit with connector)pang auto tranny talaga,nag advice skin ung tyuhin ko sa US kasi sa tranny shop din sya nagwork.kinabit namin ung sensor bulb sa oil pan ng transmission(sa drain plug).
November 10th, 2005 09:45 PM #30Originally Posted by pentot2
in plain english, ito yung pinakamataas mong gear. don't be confused by the term OVERDRIVE. akala kasi ng nakararami, pampabilis or pampalakas ito ng car. hindi po. usually, meron pong separate button for increasing the power of your car for A/Ts, but this actually only delays the shifting point to a higher rpm.Signature
high idle RPM at engine start
