Page 1 of 6 12345 ... LastLast
Results 1 to 10 of 57
    Apr 2005
    When idling, usually waiting for something/someone, for more than a few minutes...say 30 minutes or so, do you put the transmission in N or in P? Seems like a gray area in the user manual.
    I don't wanna turn-off the engine instead since i need the aircon running...
    Jun 2004
    N or P should be ok. Park is used if you would alight from the vehicle. I wouldnt recommend idling for 30 minutes regularly though.
    Sep 2004
    Waiting for the green sa stop light? Neutral, parang isang click lang nasa drive ka na.
    I guess the only time I use the park is when I turn off the engine.
    either way would be fine. pero since andun ka lang naman sa loob ng car, sa N nalang then use your handbrake.
    Signature
    Oct 2005
    pasingit lang po kasi malapit na kami bumili ng sasakyan na A/T kaso hindi ako marunong magdrive ng A/T hindi ko pa natry magdrive. Pag start pa lang ang sasakyan ok lang ba kahit saan nakapwesto yung Kambyo o sa P lang, may D2 at D4 yata para san yon? kung nasa D ako at magrereverse ako kelangan ko pa ba idaan sa N o deretso sa R na? Yung OD pwede ba on/off habang umaandar yung sasakyan? TIA
  6. #6
    p-park...obvious, park
    r-reverse
    n-neutral
    d-drive
    d4-4thgear(optional, if theres no OD switch)
    d3-3rd gear(optional, if theres no OD switch)
    d2/2-second gear
    L/1-first gear
    +/- mode: semi auto mode...acts like a manual tranny..
    OD- normally you just left it on...for optimum fuel efficiency..
    i tell you, matututo ka lang ng a/t kung meron ka na..kung wala, di ka talaga matututo...as per experience, diba?
    most new cars, hindi magstart unless nasa P ang shifter mo.
    for normal driving, use D. kung meron overdrive (OD) switch ang car mo, usually wala ng D3 (for 4-speed A/T). use D2 or D1 for steep inclines or downhills.
    kapag nasa D ka at magreverse ka, sigurado naman na idadaan mo muna sa N ang shifter mo.
    Signature
    Aug 2005
    for AT engine, when overtaking , ok lang ba yun nasa D ako tapos apakan ko accelerator after that release ko, then shift sa 3 and accelerate again to gain more power?
    when you press hard on the accelerator, the transmission will downshift. no need to shift it manually. unless your A/T is the steptronic type.
    Signature
  10. #10
    pwede mo apakan ng todo, automatic na mag-ddown shift un, pwede mo din i-off muna ung OD(or shift to D3), ganun din effect nun...
Question on N(eutral) or P(ark) in A/T cars
