Results 1 to 8 of 8
    Jun 2007
    normal lang ba na nag aadjust ang rpm pag on and off ng over drive?
    kase yung sakin dati nag aadjust pa. ngayon hindi and napansin ko na parang hindi na umaakyat ng 4th gear and super taas nya mag rev na parang hindi tama yung speed nya.
    anu problem pag ganito?
    Nov 2006
    how many gears does your transmission have?
    lets just say you have 4 gears(4th gear being O/D)if your on 4th gear already and you disingage your O/D..its normal for your RPM to go high since the transmission is dropping to 3rd gear at the same speed.
    tama si sir deedee. pero kung sabi mo na parang nde na nagshift at mataas yung rev, may problema nga talaga sa shifting yung trans
    Jun 2007
    bro ganito situation. say naka park ka or neutral. 4 speed automatic ah
    dati kase if i turn the overdrive on or off nag aadjust yung rpm. ngayon hindi na. steady lang rpm.
    ngayon pag umaandar na. parang over rev ang nangyayari and kulang yung speed niya kesa dati.parang wala na sa timing pag shift. and parang hindi na pumapasok yung 4th gear.
    nangyari 2 after ginamit ng bro ko yung car na walang odometer. nililinis ko kase dashboard.
    badtrip. help naman pu.gusto ko mabalik yung dati nya sigla
    bro, check your transmission's fluid, pag medyo amoy sunog na, isang indication ito na me problema na sa transmission mismo.
    Nov 2003
    rpm should change when the od but is engaged or disengaged.
    Baka naman hindi na-e-engage ang O/D when you switch it on. Check this first. I understand, unusually high RPM and not the right speed?
    5606:jazzysax:
    Jun 2007
    5606:jazzysax:
    yup bro high rpm tpos not right speed. may lam ba kayo shop na nag babago ng shifting time ng a/t ? say gusto ko mag shift cya ng 20-30 2nd gear, 40-50 3rd gear 80-90 4th gear.
    kase yung akin nag shift cya ng 10 2nd gear 30 3rd gear 60 4th gear dati hindi naman cya ganun
overdrive  question
