Results 1 to 10 of 22
April 12th, 2004 09:12 PM #1
Guys,
I noticed that when I press the clutch, certain noise tends to disappear and re appears when not pressed. What's this? I don't see any problem with the clutch yet because I am not experiencing any slide.... thanks in advance...
April 12th, 2004 09:20 PM #2
akin naman squeaking noise tuwing apak ko and twing tangal ko apak clutch... magagamot ba ito ng wd40?
hehe
Tsikot Member Rank 3
- Mar 2003
- 637
April 12th, 2004 09:30 PM #3ganyan din yung sa clutch namin may squeaking sound kapag inaapakan at binibitawan. pero minsan wala minsan meron and wala naman makitang kailangan langisan. :confused:
April 12th, 2004 09:35 PM #4
gregg_g::: Symptom of a misaligned clutch release bearing. Nothing to be alarmed about. This part will still perform its task until your clutch needs replacement. Btw, how far has your vehicle travelled? You may need to be wary of clutch slipping sooner or later.
April 12th, 2004 09:36 PM #5
How many years na ba yun Car mo? if it's older than 5 years then it could be of the FF reasons;
1st - if the sound is like a Jungle Rattle then it could be the loose springs of your clutch disc.
2nd - if it's caused by a vibration, it could be your plywheel or pressure plate having uneven surface bcoz of wear and tear.
3rd - if squeaking noise, it could be your clutch pushrod hitting the rim of the master liner w/c is caused by misaligned or loose bolts of your master.
4th - if it's still new i suggest you have it checked w/ your Casa to avoid voiding wrnty.
Oh i see that u hav a Mit Paj, if it's from subic, better chk the alignment of the push rods and the pivoting points of the clutch pedal itself.
WD40 could solve the noise but its temporary solution only...
April 12th, 2004 11:01 PM #6
ganito rin sakin...may ingay na nawawala pag naka apak ako sa clutch..pag naka release...may ingay.
April 13th, 2004 06:42 AM #7Originally posted by snyc3
I think its more of the no 1 and 2, I bought it a month ago, its a 2nd hand with 71k on it...
Ungas
Thanks...Last edited by gregg_g; April 13th, 2004 at 06:45 AM.
April 13th, 2004 09:11 AM #8
I had a similar problem before ( a ringing sound) and it turned out to be the release bearing.
April 13th, 2004 10:04 AM #9
pagtyagaan mo na lang muna ung ingay na yun. sayang kasi ang ibabayad mo sa labor pag papapaltan mo ung release bearing lang.
isabay mo na lang sa pagpapalit ng clutch.
Tsikot Member Rank 4
- Feb 2004
- 1,704
April 13th, 2004 10:06 AM #10pajero na gen 2 ko ganyan din !!!!!!
88,000 kms ang mileage. does this affect the transfer of power from the engine to the wheels?
andy
I agree. travelling by train is always the fastest way to travel. kami din dati sa Bangkok, we...
Makati Subway. Completion date: 2025
