Results 1 to 3 of 3
- Jan 2013
- 178
August 18th, 2016 11:32 PM #1What is the difference between multi and monograde gear oil? Some said di raw safe ang mono dahil pag iminit mag shear daw unlike multi. Umaabot ba ng 100c ang tranny? Ang alam ko walang winter dito satin kaya ok lang ang mono. Tama ba ko? I am now using sae90 on my celerio. Shell spirax gearoil
Sent from my ASUS_Z00LD using Tapatalk
August 19th, 2016 12:04 AM #2
- Aug 2013
- 475
August 19th, 2016 09:05 AM #3mas maganda multi grade na gear oil kesa sa mono grade.
ang multi grade, kahit hindi pa mainit yung tranny, smooth shifting na siya, di tulad sa mono grade, kailangan pang uminit para maging smooth.
ramdam na parang tumigas yung pagshift kapag mono grade. sa ibang tranny, may sabit pa minsan kapag hindi pa mainit.
based on experience.
toyota gear oil VS thuban sae90 ng Caltex yung nagamit ko dati.
high idle RPM at engine start
