Page 1 of 2 12 LastLast
Results 1 to 20 of 28
    BEWARE OF LEONARD BULAONG
    I was the owner of the Rav4 the one SIR JEKBU said on this thread --> http://tsikot.com/forums/transmissio...t/index24.html. Congratulations to you, it was solved easily.
    UNFORTUNATELY, I experienced the other way around, or should I say WORST than what happened to sir COCOY 2 years ago here--> http://tsikot.com/forums/transmissio...t/index13.html. Bad thing is, I still went on to see LEONARD BULAONG and did not took sir COCOYs bad experiences as a warning.
    This was transpired during my HELL week;
    Day 1, Monday, 25 August 2014
    Went to see LEONARD BULAONG to check my tranny. However, the situation seems to be odd because they don't have shop anymore. What happen was we met at Banawe and asked to drive to the direction he said in Manungal St. Tatalon.
    His father, Alex test drove the car and check the problem. after test drive, LEONARD said the tranny should be brought down and was given me 2 options
    1) Original will be replaced by Surplus Tranny parts, 1 year warranty.
    2) Rebuild the tranny with original parts, but 3 months warranty.
    I chose #1 as he is telling me its the best option, he priced me 32k initially after nego we agreed to 25k. Then we agreed that the tranny will be done at 8pm, so I waited. They are just working on the street side where parking is not allowed. Even the baranggay police warned us that the owner of the car will be fined. But leonard said "akong bahala" dyan.
    From 9AM-3PM, they have done nothing as they are busy working on the other client na napakabait, so I have no complains. To think they have only one Jack for a "transmission specialist". So they couldn't work on both.
    Then when my turn went in, they dismantled the tranny and ended at around 6pm. That time LEONARD already asked for 20k downpayment so they can buy the surplus tranny that I have never seen - but I still trusted them. Then I was informed that the bearing should be pulled and machine shops are already closed.
    I was so disappointed because they didn't anticipate that thing when they are dealing with me knowing that they are working with trannys all their life (as they say)
    So I have no choice but to go home empty handed and my car is parked illegally and its tranny are torn apart. But, I still big hopes that everythings going to be alright the next day as he promised, it will be up and running before 11AM.
    Day 2, Tuesday 26 August 2014
    I called LEONARD at 9pm to check if the car is already running, then he said, "nakabit na pero binaba ulit kasi me tagas ATF" (Lie #1). I was there at 11am and the moment I came Alex bulaong is still assembling the tranny, so I asked him..."sayang yung unang kabit tapos na sana kaso nagkatagas daw eh no?", alex replied "d pa naman nakakabit to inaassemble pa namin eh?" i said, kala ko nakabit na kanina..., he replied "hindi pa". So i just kept it on my self.
    Then he asked for another 1k for the ATF and which I noticed he just used the used one. Then I told him "bakit nde lahat bago nilalagay mo?", he told me "okay nya yan CVT pa yan". - nice right, but I let it pass once again.
    The car was assembled again and when i test drove it, it seem everything is noisy and loose - and the tranny problem is the same -> plus more problem. Then we agreed to have it ECU scanned which I believe that should be done before bringing down the tranny.
    After the scan, the technician told us that it has a tranny problem and coudnt isolate if ECU issue as the performance is the same using brand new ECU.
    Once again I felt hanging to this situation
    1) If the tranny components were already replaced, why the same problem occurs?
    2) Why we didnt go on to ECU and other electrical components first before we brought down the tranny?
    Once again, the situation left me with no choice but to go home with nothing but headache and frustrations. Then I decided to leave the car to LEONARD to give him time to work out on the problem.
    Day 3, Wednesday 27 August 2014
    I tried to focus on my work and just phoned LEONARD to seek updates. His update was
    LEONARD: kailangan tong palitan valve body
    ME: Kala ko pinalitan mo na lahat ng laman loob
    LEONARD: dapat brand new
    ME: cge kung sure ka ba na yun ang problema eh.
    LEONARD: sure yun napascan ko na eh.
    Day 4, Thursday, 28 August 2014
    I called LEONARD to seek updates
    LEONARD: sa friday pa dating ng valve body, inorder ko pa sa casa
    ME: okay, sure na ba yan
    LEONARD: oo sure na 11AM
    DAY 5, Friday, 29 August 2014
    LEONARD: wala pa check ko mamaya
    Me: cge, balitaan mo na lang ako, sabi ko puntahan na lang kita bukas.
    LEONARD: mga 11am pa ako available
    ME: cge dun na lang ako tambay sa Manungal st.
    LEONARD: nasa casa ang sasakyan nde ko mapull out kasi nakapila (Lie#2 - casa)
    Me: okay, cge dun ko na lang puntahan, sino contact natin dun
    LEONARD: si marlon
    Day 6, Saturday 30 August 2014
    I was really thinking to pull out the car from him because its not making any improvement yet I suspect its just getting worst. So I went to his place early in the morning (Manungal St. Tatalon) and nobody was there including my car. So I ask somebody from there and he said "anjan lang si 'nard paikot ikot tinetest drive ata oto mo" - so okay, the car is not in the casa.
    So I called him,
    Me: Asan ka? Asan oto?
    LEONARD: nasa casa nga diba???
    Me: (Calmly said) okay, dun na lang tayo magkita(casa), checkin ko na rin kung magkano magagastos natin dun...
    LEONARD: okay.
    then eventually called me back after 1 minute using other number
    LEONARD: dito ako sa Mazaraga eh.
    ME: okay sige dun na lang tayo sa casa magkita.
    LEONARD: Okay.
    So I went to casa and check with the service if my car is there for checking - NONE, WALA, NADA(so confirmed that everything was I lie, even from the start I given him the benefit of the doubt). Then I called LEONARD, just to tell him just bring my car in Toyota Quezon Ave, then I waited 30mins to think he is just 3 blocks away, and every time I called he said he is on his way.(Lie)
    Then he arrives, I hitched in the passenger side, the moment I got in, he said the problem is still the same, no improvements. But I really got disgusted the way they treated my car;
    1) The car smells the hell of smoke - MAN, I never allowed someone to smoke in my car.
    2) Upholstery and dashboard are full of grease and black dirts.
    3) My loose coins are gone.
    4) Alarm is not working
    5) ATF is leaking
    6) THe whole engine bay is wet with ATF
    7) The wheel alignment is a mess - which not be moved becuase they are working only in tranny.
    8) I left the car with 34kms in my trip meter, and got it 145kms - where the hell my car went? that's too much for a test drive.
    I said to myself, "What the hell I got into?"
    Then, I said I will pull out the car and just sell to somebody, since they aren't able to fix it. And I demand only for the half of the payment I did i.e. 10K which he agreed but he said he will just deposit it on Monday, 1 September 2014 OR Tuesday 2 September 2014. I think that's fair enough to both of us considering my car hasn't improved a bit. I could've ask for full refund for the mess he did, but no, I'd still want to be fair.
    BAD NEWS is, today is already Wednesday and no money is deposited. Tried to contact him every now and then but he always give excuses...in short...pinapaikot lang ako.
    With this experience, I learned the hard and expensive way. I just lost too much;
    1) My hardly earned money (downpayment 21k, taxi cainta - qc back and forth ~1500)
    2) My time and effort
    3) Car degradation
    4) And too much stress dealing with this person.
    I could've just kept silent but I cant let this kind of trade continue. For me...YOU JUST BEEN WARNED! I rest my case.
    Last edited by legriv; September 3rd, 2014 at 05:19 PM. Reason: added forum links, updated the title
    Binugbog mo sana
    Sent from my iPad using Tsikot Car Forums
    #retzing
    Bad trip nga naman...
    Sarap upakan.
    That's why I don't trust anyone from banawe that does not have a shop.
    Sad to say that your money is gone.
    Dec 2012
    Ok na ginawa mo. Reduce your losses. Balikan mo hagisan mo sila granada. Mga put*#!
    Feb 2005
    More than 100km? Wow that's a lot. Nagpunta atang Bulacan yan. Sorry to hear about your experience!
    Quote Originally Posted by kotiko View Post
    Yun ang hinala ko kasi taga bulacan daw sya eh...mukhang kilala mo sya sir kotiko ah.
    Jun 2007
    takutin mo nalang, sabihin mo bahala na RIT (riding-in-tandem) sa kanya kung hindi siya mag-dedeposit
    Feb 2005
    Quote Originally Posted by legriv View Post
    Ay hindi, Dapat Laguna sasabihin ko pero narealize ko mas malapit Banawe sa NLEX. I wouldn't be surprised if he did, going around Metro Manila wouldn't easily result to 100km unless taxi driver ka.
    Anyway, it's every car owner's worst nightmare... to pay for a hefty price and none of the problems gets solved and get the car in a worst condition afterwards...
    I had my fair share of those kinds of experiences too and until now masakit parin sa puso pag naalala.
    I just remembered the TV5 Tulfo brothers show that I chanced upon last night... If you want to take matters to the next level! Pero sana you get your money back.
    that sucks. dapat talaga ma-warn iyong ibang may problematic trannies para wala na maloko iyong mga iyan
    Kasi naman if your car need a major repair tapos nakita mong walang shop Sa tabi na lang ng kalsada kahit gaano pa siya kamiya hinde na bale. Magbayad na lang ako ng mas mahal safe naman kotse ko.
    Posted via Tsikot Mobile App
    Aug 2010
    Sorry to hear about your bad experience sir legriv. Others will be informed because of this. Karma nalang sa taong yan. Hopefully maibenta niyo nalang yang Rav4 niyo soon.
    May 2013
    agree with shadow. pag malaking gastos, dapat talaga sa mekaniko na may shop na. nadala na kasi ako noon dyan sa mga hitmen sa banawe, yun mga nasa kalsada na kumokontrata tapos hindi pala sila ang titira. akala ko noon makakadiswento ako. mas makakamura ka pa pala kapag sa shop mo dinadala. lalo na kapag nakaibigan mo na yun mekaniko.
    thanks for the heads up.
    Nov 2013
    Unless kakilala mo yung nasa hole-in-the wall na mekaniko. Kung wala pa masyado kakilala, wag na mag-alangan sa mas mahal na presyo ng mga established shops. Kadalasan wala kang habol sa mga naglipanang siraniko.
    Mar 2004
    This is going to be harsh ...
    For want of a cheap service repair, you end up paying more plus a lot of headaches. Most likely you car parts have been sold and replaced with even more defective parts. Why in the world would you leave your car to a stranger who left it in the sidewalk? Did you think that changing a transmission was just like changing tires? That it would just take a short time and no problems would arise? You might as well have put a sucker sticker on your forehead.
    Jul 2012
    Very bad decision indeed. Parking nga sa labas nakakatakot na, iwan mo pa sa di kilala tapos walang shop. Wala kang habol dun kung carnapper yan. And for 21k, malaking pera na yan. Nagtipid kapa. Charge to experience na lang. I hope bago mo benta ay pagawa mo muna, or kung di mo naman papagawa, be transparent sa pagbebentahan. Goodluck and thanks for the warning.
    Jul 2011
    lesson learned nalang ts, nagkamali na, wag nalang ulitin. medyo pricey
    yung pagkakamali, pero ok na yan, atleast nasayo pa yung kotse,
    buti nga at binalik pa sayo, kung tutuusin, may chance pa nga na
    hindi mo na balikan kinabukasan yung kotse, exposed na exposed sa
    lahat (carnapper, mangbobote, banawe boys), just be more wise nalang
    kung saan dapat magpagawa ng kotse next time.
    and as stated previously, be honest nalang sa next owner.
    i have question...
    what is the batting average of AT fixes? i have heard someones say that it is better to completely replace the AT than to have someone open it and fix it...
    Jul 2014
    Mas okay ang rebuild kaysa bumili ng surplus gear
    Tsikot Mobile App
    Jun 2007
    repair cost can range from 10K to 40K, depends if the damage is light or severe.
    what's better, surplus or rebuilt tranny? it depends, both have their own pros and cons
    for a surplus tranny, you'd be able to save up on labor coz the mechanic would just have it fitted, filled with ATF, and tested (this is a mechanic's preferred method coz of less effort. easy money). additionally, you don't have any idea the history of the tranny. so basically, a hit or miss. compared to rebuilding a tranny, it would take some time to dismantle, repair/replace parts, assemble, fit, and tested -- reason for a high labor cost. however, this is also a hit or miss, coz the quality of the newly rebuilt tranny depends on the mechanics skills on putting back the parts together properly. if you've got a lousy mechanic, befriend him coz definitely you'll see each other more often.
    Apr 2010
    i have question...
    Unsure pero parang around 40k ata yung sa akin, laki kasi ng patong ng Petron C5. Kaso nilibre ako sa pagpa-rebuild kaya ok lang I've documented my experiences in this thread/ .
    First three weeks rough ang shifting and may vibrations pero I was told na to wait until a month. Buti naman umokey na and now it runs like new , no hesitations or shifting problems encountered until now.
    Kahit na let's say ako nag shoulder nung 40k mas may peace of mind naman ako and may matatakbuhan akong shop in case problems arise. Yung mga hole-in-the-wall shops OK lang yan for minor jobs or kung kakilala mo talaga yung mekaniko but I wouldn't risk my vehicle to another person na di ka sigurado.
Warning to all looking for Transmission Specialist
