Results 1 to 6 of 6
- Aug 2014
- 391
June 22nd, 2016 07:50 AM #1Guys,
Unit Po: Isuzu Hilander 2000 Model
Manual Transmission
Problem encountered:
Tumatakbo pa naman, pero may instance na pag 2nd gear, parang walang power, nag hahigh rev, pero di umususad, till few seconds, kakagat na ang gear, ganun din sa 3rd gear, pag change to it, mabagal masyado mag engage, mag hahigh rev muna din mag normal ang rpm at engage ang gear. Ano kaya posible problem.
Visible problem:
-Merong leak ang slave cylinder nung clutch, pero di naman nauubusan.
-meron din leak yung oil seal between transmission and shaft nung engine.
appreciate any advise.
thanks
- Jun 2005
- 3,774
June 22nd, 2016 08:11 AM #2Nasagot mo na po ang tanong mo.
Fix the obvious first, sir.
- Jul 2010
- 165
June 22nd, 2016 08:45 AM #3Sir baka palitin na ung clutch ng isuzu niyo. Kung hindi pa napapalitan yan since yr 2000.
- Aug 2014
- 391
June 22nd, 2016 09:01 AM #4Yung Clutch disk ko, bagong palit, mga 6 months pa, yung slave cylinder, will DIY replace this weekend. Naisip ko lang, yung oil seal, napalitan na din kaya lang, medyo palpak yata pag salpak ng mekaniko dahil merong konting leak na naman, pero di naman cguro aabot yung leak nun sa clutch disk na pwedeng mag cause ng sliding?. Salamat.
June 22nd, 2016 10:27 AM #5
yung leak sa oil seal natatalsikan ng oil yung clutch disc kaya sliding. pag nag high rev ka na-expel yung oil sa disk kaya kumakagat na ulit.
June 22nd, 2016 12:18 PM #6
your post does not indicate harsh engagement and does not indicate you have noise.
the only indication on the post is that it slips periodically.
the only thing that comes to mind is the cleanliness and the preparation prior to the clutch disc and the adjoining friction components ( flywheel and pressure plate). given how sloppy most "mechanics" are, the most likely cause was that the friction components were either touched with oily hands or the pressure plate was not rinsed off of the corrosion protective l on the pressure plate.
Anong Chinese brand na ba ang available sa market? Yung Leoch brand may nakita na ko post sa FB....
