Results 1 to 15 of 15
    Jun 2008
    Hand brake yan kumakapit pag reverse saka biglang bibitaw sa brake drum. For me it's just normal.
    Sent from my Lenovo A7000-a using Tsikot Forums mobile app
    Quote Originally Posted by weisshorn View Post
    i beg to dis-agree. the release should be soundless. if it makes a sound, then there something that's sticking. i encounter this in my (non-mirage) car, after wading thru a flood.
    Apr 2014
    afaik. halos lahat ng mirage m/t eh nararansan yan.
    it has something to do with the mirage being low cost. i forgot the tech reason since that was 1 full year ago pa nung inexplain sa amin.
    kelangan full stop bago mo i engage ang reverse.
    may mga iba na engage muna first gear then go to reverse and nawawala yung ingay.
    personally, full press ako sa clutch and todo kambyo (farthest right) to go to reverse.
    kapag lousy ang pag engage ko (half clutch and malamyang kambyo), dun sumasabit.
    HTH.
    it's one of the quirks of this car.
    first, the celerio MT. now, the mirage.
    unti-unting lumalabo ang pag-tingin ko sa mini cars...
    heh heh..
    Apr 2014
    just remembered the reason:
    its about the unsynchronized reverse gear.
    Quote Originally Posted by chronicle View Post
    they scrimped on the reverse synchronizer!??
    Apr 2014
    Cost cutting.
    Honestly, i was dissapointed with the new facelifted mirage as they did not improve this part. Anyway, this is more of a nuisance and not a big issue (i hope).
    Sent from my Z410 using Tsikot Forums mobile app
    Feb 2009
    First gear and reverse gear have never been synchronized for manual transmission. I have been working on cars as a hobby and professionally but I have never seen synchronized first nor reverse
    Oct 2009
    heh heh..
    ung spark nung uncle ko.i year palang katakot takot ng problema inabot.hindi makita kung san nanggagaling ung katag sa harapan.after nun ung brake cylinder naman ang nag stock up.kahit ginagamit 3 times a week.
    Oct 2015
    Salamat po sa mga nagcomment, pero mukang lalo diko alam gagawin LOL :-)) So anu po verdict nyo? May nakapagsabi yung "pag sa umaga", tama po pag malamig makina sa umaga, pag reverse ko, dun sya pinaka maingay, like "ngararggagagarag!!!!" Ganun. para kasing 50/50, may normal at merong di msyadong normal. Di pako nagpa pms kaya diko pa din natatanung sa kasa.
    Ang ginagawa ko ibabalik ko sa neutral, then mala smooth na tyempuhan ng reverse. Iniisip ko baka walang fluid??? pero yung mga bagong car electronic eh.
    Quote Originally Posted by Salanguit View Post
    if the clutch is adjustable, see if it disappears when the clutch is re-adjusted for less slack.
Mirage reverse shift
