Results 51 to 60 of 101
- Jan 2005
- 9
January 12th, 2005 11:37 AM #51Hi guys!
newbie here.
just got across this fun site 2 days ago.
i drive an invecs2 lancer.
i rarely use the semi-manual/auto gear (katamaran).
my question is, would i be saving more gas using it than driving fully auto?
January 12th, 2005 08:09 PM #52
Originally Posted by Rediesel
What you do if you need added ooomp is to downshift.
How ? TURN OFF O/D , The A/T will downshift to 3rd gear then floor it , it might downshift to 2nd or if you have enough speed already the A/T will hold 3rd then you will see the Tach climb up to near redline (if it needs to) .
Anyway, with the O/D on or off in my car, if the shifter is in D, the engine will never reach the tach's redline. It will shift around 4000rpm (redline at 6300).
January 12th, 2005 08:10 PM #53
Originally Posted by mlance02
January 12th, 2005 08:48 PM #54
i'd stick w/ an A/T car, altough i drive a manual. if you need power, go get a car w/ a bigger engine. M/T cars are so tiring and stressful to drive nowadays given the traffic condition we have.
January 12th, 2005 09:06 PM #55
very responsive na mga new a/t's today. sarap talaga mag drive sa a/t. yung patrol ko na nga lang ang m/t dito
kaya ayaw kong i-drive masyado yung previa, baka masanay ako at tamarin sa m/t
Signature
January 13th, 2005 07:59 PM #56
For me M/T pa rin although i drive an automatic. My observation lng is they are almost the same in acceleration basta ung car in motion na, pero kung galing from a stand still position malaki talaga advantage ng M/T.
Also i think that A/T uses more gas because its idle is around 1000rpm minimum unlike M/T which is ok at around 700rpm.
January 13th, 2005 08:09 PM #57
Signature
January 13th, 2005 11:13 PM #58
If only there were locally available A/T versions of GEN II 4d56 Pajeros...
But there were none, so tiyaga na muna with the manual.
January 14th, 2005 07:41 PM #59
kahit ano sabihin niyo, manual pa den ako. sanayan lang yan.
mas enjoy ako sa manual maski laging traffic sa manila.
nababagalan ako sa a/t. tas lagi ko pa naiisip ung gas consumption ng a/t.
tas parang scooter lang ung dinadrive mo, gas pedal and brake na lang.
nakakaboring for me. siguro pag nagkapamilya na lang ako.
sa m/t nakaka abot ako ng 14km/li
laking tipid din saken nun. estudyante pa naman ako. wala namana ko trabaho para magpagas ng magpagas.
so m/t is my vote.
January 14th, 2005 11:59 PM #60
gusto ko ng sportronic! i would love to drive one... everyday
but after seeing drift bible... manual pa rin :D
Eto nalang gawin, kunin starter relay at fuse pump habang ginagawa pa yung key fobs. ...
