Results 1 to 15 of 15
    Mar 2005
    guys,
    is there any way to make the clutch pedal of a car softer & easier to step on?
    napansin ko kasi malalalambot tapakan mga new manual cars compared to the one am using. pwede pang ipaayos ito para lumambot, kasi nakakangawit pag long driving at traffic. kung pwede san at may mga parts ba na kailangan palitan?
    need your help car gurus!
    depends on the car... if its a cable type clutch, you can add some oil into the cable tube to aid lubrication.
    Jan 2004
    Quote Originally Posted by malufets
    guys,
    sir,
    isa sa mga probable na diagnosis kung matigas na tapakan ang clutch ay baka pudpod na clutch disk. you may want to have your clutch parts checked. they may be worn out na. I recently has my clutch disk, pressure plate and release bearing replaced, ayun, lambot na rin tapakan.
    what car do you drive?
    Mar 2005
    2000 Honda SIR po bossing. 25t km plang. actually d naman siya matigas, nasasrapan lang ako sa lanbot ng clutch pag yung bagong revo namin gamit ko.
    the last 3 cars i have are all matics, so medyo dali mangawit ng left leg ko. i just wanted to know, if sumthing i can do about it, not having to replace some major parts. kaya pa bang makuha lambot ng mga bagong auto? yun lang po
    thank you all for the replies!
    yeah..dfepends sa car....sa patrol safari, i change the release bearing to larger ones.
    Feb 2005
    Pour some lubricating oil on your clutch cable and have our clutch pressure plates checked.
    May 2004
    If your car has hydraulic clutch system, you can add clutch booster. its like a small brake booster for the clutch. Try to peek into an engine bay of nissan patrol GQ and GU M/T...
    Jan 2004
    What kind of oil should I put on my clutch cable? Thanks!
    Quote Originally Posted by ching
    for me, I used motor oil.
    yup, check your clutch system, baka worn out na nga. somebody here told me to replace a bigger fork, yung nag pu push ng release bearing. This might help.
    Jan 2004
    Last time that happened to me it was already due for replacement... How long has it been since you replaced yours?
    Nov 2003
    yung lambot is dictated by the masters (if functioning properly), the release bearing and the pressure plate.
    replaced by release bearing before kasi maingay and the good side effect was na lumambot konte yung pedal pressure ng auto ko.
    afaik mas matigas talaga ang clutch ng civic sir compared sa ibang 1.6 cars.
    Kung gusto mo lumambot, ipagawa mo dun sa mga sira ulong gumawa ng clutch ng MB100 namin (BW sa Banawe). Banas na banas na ko para kong walang tinatapakang clutch. Ang hirap tuloy timplahin.
how to make clutch pedal softer to step on?
