Results 1 to 5 of 5
- Jul 2007
- 11
September 20th, 2007 10:23 PM #1help me pls. i have a toyota corolla 89 model, when i tried to shift the gear in 3rd gear it has a weird sound and somtimes it does not enter the 3rd gear, i went to some mechanic to consult the problem they told me i have to replace the transmission of my car, they told me it is repairable but they advised me it is better if i replaced the whole transmission device..
i look for a surplus of a transmission device and it cost about 9k without the labor.. need help should i buy a transmission or anyone here know where could i bring may car for the repair of transmission..please help
September 21st, 2007 07:24 AM #2
mahal yang 9k for an 89 model toyota, sa mitsubishi lancer na 1997 ganyan ang presyohan ng surplus manual transmission eh, mas bago pa yun.
Suggestion, do the cheapest solution first, palitan mo muna ng gear oil. If that didn't work, have your clutch components checked, this requires pulling the transmission down.
If your clutch components are worn out na, replace them. if the problem is still there, it could be your transmission gears are worn out na, then that's the time to get a surplus transmission.
- Jul 2007
- 11
September 21st, 2007 12:09 PM #3sir maraming salamat sa reply mo. tanong ko lang may ma recommend kabang magaling sa mga ganitong problema yong tipong hindi ako lolokohin sa presyo
September 21st, 2007 02:28 PM #4
- Jul 2007
- 11
September 21st, 2007 10:36 PM #5sir ARTPOGI salamat sa tulong mo text ko siya pero puntahan kaya niya ako, cavite pa kasi ako nakatira pero text ko nalang siya.
one more thing sir may alam kabang magaling na latero yong auto ko kasi medyo malaki yong tama sa likod kinain na ng kalawang yong sa left at right side niya sa ilalim na malapit sa gulong sa likod kinain na rin ng kalawang
