Results 1 to 3 of 3
    pag umaga ganda ng apak ko parang papel pero habang tumatagal sa byahe ex. from Katipunan - Espana naninigas na clutch ko "tumutukod" na
    help me pls... hu has an idea??? my ride is 92 nissan power pickup TNX
    help need ur comments
    Jun 2005
    *co_nixz
    Is your clutch system cable or hydraulic type?
    You might want to have the following checked:
    a. Hydraulic type:
    1. Hydraulic fluid = is it still the same color a the one from a newly opened bottle? If not then there might be "passing" or leak on your seals which brings me to the next item.
    2. Clutch master/slave cylinders = the rubber seals, valves, valve springs may be due for replacement. May mga repair kits naman.
    3. Hydraulic fluid delivery system = check the hydraulic lines to your cylinder. there might be leaks.
    b. Cable type:
    1. Put some lubrication on the cable hose or you might have to replace this.
    Have the clutch disk & pressure plate checked including the bearing (medyo mahal ito) if all of the above are ok.
Im having problems w/ my Clutch help
