Results 1 to 20 of 39
    Nov 2003
    sure, there's a drain plug then just refill it by removing the speed sensor and filling up through that hole.
    ah ok. salamat mga bosing sa mga inputs niyo ilan liters din pala kelangan ko?
    pero i just wanna ask if this one's ok too. its the castrol mtf; see link :http://www.castrol.com/castrol/produ...tentId=6005074. i just wanna satisfy my curiousity
    Jun 2006
    When do you normally replace the gear oil or manual transmission fluid? In terms of months, years or kilometers pls.
    Quote Originally Posted by userfriendly View Post
    ako every 40K kilometers
    Depends on the vehicle. On my old Besta, a change was called for every 20,000kms. Relatively a short interval. Kaya yun na din ginawa ko sa Pajero. Sa Vitara, longer ata ang interval.
    Sep 2005
    thanks sir otep and sir migs, I'll check kung kaya ko with my available tools kung pwede DIY. btw, mga ilang liters po ba kakainin ng eg sedan ko?
    Jun 2006
    for diesel--- gear oil 90 is mostly used aside sa isuzu which they used enigne oil with 15w40 grade.... but it wold be better if you could use a 80w90 gear oil for your transmission....
    gasoiline---- honda uses ATF dexron III... ewan ko lang kung ano ang gamit ng ibang model....
    Nov 2003
    sa honda normally 2.5 liters. don't use anything but engine oil. the 75w90 or 80w90 gear oils normally make the tranny a bit notchy and hard to engage kapag malamig pa makina.
    GEAR FF-LSD TYPE 2 is motuls oil for lsd tranny's while MOTYLGEAR is the regular fully synthetic gear oil, GEAR 300 is the ester based gear oil.
    http://www.motul.com.ph/main.html
    I was wondering kung pwede gamitin yun Dexron 3 dito eventhough Dexron 2 ang specified sa manual? Padrain ko siguro?
    Tapos plano ko bumili ng GEAR FF-LSD TYPE 2 since 2-wheel drive yun Sonata ko
Manual Transmission Fluid - help!
