Results 1 to 13 of 13
    Sep 2011
    sir tulong po hindi ko po alam kung ano po sira ng traansmission ko sana po matulungan nyo po ako salamat
    Mas maganda nyan brader sabihin mo kung anong oto mo.
    yes give more info like year model, engine, transmission, etc , also your location
    Feb 2009
    diagnoses done here, sir. just give make, model, year, engine size, transmission type, mileage, last fluid used and the most recent thing done immediately before symptoms started.
    Jan 2009
    My pregio was fixed in banawe. Bulaong tranmission specialist. Up to now ok pa yung ginawa nila...
    Sep 2011
    mga sir sorry po, b18c a/t honda engine--body vti 99, hindi ko na po alam gagawin ko miss ko na po ung kotse, hindi ko po kasi alam kung ung transmission ung sira o ung electrical kasi po, since po na nilinis ko ung engine tapos po pina engine wash ko ayaw na po magshift ng gear, sana po matulungan nyo ako maraming salamat po more power po sa tsikot.com
    you have to get it scanned first assuming that the fluid level is right and go from there.
    Feb 2009
    Quote Originally Posted by islajv View Post
    have the pcm scanned for diagnostic trouble codes (dtc's) and record. with battery disconnected, disconnect the wires leading to and coming out of the automatic transmission. once the terminals are exposed, spray wd 40 on them and let drip. to protect the problem from recurring, protect the wire connector with dielectric grease or vaseline to make them waterproof
    Sep 2011
    opo sir nasa hi level po at pink po sya, malinis p po ung fluid
    Sep 2011
    salamat po sir jick,
    Jun 2011
    sir san po b kayong lugar?baka maka tulong ako sayo.
    Jan 2012
    Hi,
    maki tanung nalang din po, bago po kc ko.
    ask ko lang po, kung rebuilding kit ang kailangan, mahal po ba o mura ung estimate sakin na 21k kasama na labor japan surplus daw po ung ikakabit, please help kung meron pang ibang paraan maayos ung hatak. lancer 94 AT po ung sakin
    Jul 2006
    mga gurus need help po pls. I have a 2006 toyota fortuner 3.0, 4x4 diesel, ayaw po nya magshift ng gear naka1st lang po kahit na apakan mo pa ng sagad at matagal ang acceleration pedal. ano po ang dapat gawin at san po maganda pagawa, may contact number po ba kyo marerefer. thanks in advance.
san po pwede po magpadiagnose ng engine regarding ayaw po magshift ng a/t gear
