Results 1 to 10 of 13
- Sep 2011
- 16
October 20th, 2011 10:57 AM #1sir tulong po hindi ko po alam kung ano po sira ng traansmission ko sana po matulungan nyo po ako salamat
October 20th, 2011 02:06 PM #3
yes give more info like year model, engine, transmission, etc , also your location
October 20th, 2011 10:13 PM #4
diagnoses done here, sir. just give make, model, year, engine size, transmission type, mileage, last fluid used and the most recent thing done immediately before symptoms started.
- Jan 2009
- 8
October 21st, 2011 01:00 PM #5My pregio was fixed in banawe. Bulaong tranmission specialist. Up to now ok pa yung ginawa nila...
- Sep 2011
- 16
October 21st, 2011 10:57 PM #6mga sir sorry po, b18c a/t honda engine--body vti 99, hindi ko na po alam gagawin ko miss ko na po ung kotse, hindi ko po kasi alam kung ung transmission ung sira o ung electrical kasi po, since po na nilinis ko ung engine tapos po pina engine wash ko ayaw na po magshift ng gear, sana po matulungan nyo ako maraming salamat po more power po sa tsikot.com
THE AUTO SPECIALIST
- Mar 2006
- 607
October 22nd, 2011 10:17 AM #7you have to get it scanned first assuming that the fluid level is right and go from there.
October 22nd, 2011 02:46 PM #8
have the pcm scanned for diagnostic trouble codes (dtc's) and record. with battery disconnected, disconnect the wires leading to and coming out of the automatic transmission. once the terminals are exposed, spray wd 40 on them and let drip. to protect the problem from recurring, protect the wire connector with dielectric grease or vaseline to make them waterproof
- Sep 2011
- 16
- Sep 2011
- 16
alas, a nose is easily fatigued. hence its unreliability.
LTO accredited emission testing centers
