Results 1 to 6 of 6
- Nov 2011
- 86
March 7th, 2012 08:39 AM #1we have a 95-nissan series 3.
kapag nasa low gear.. 1st and 2nd.. maybe doing 30-40kph (sira na po kase ang odo).
kailangan po timplahin ang clutch pedal kase parang kabayo po pag hindi...was adviced to change
clutch disc/plate and release b.. napalitan na po ito pero ganon pa din.. i tried shifting 3rd-4th and 5th gear...
ang nangyayari po.. nanginginig pag binitawan ko na un clutch maybe doing 2-2.5k RPM... parang nangangabayo na..
ano po possible na sira?
- May 2011
- 481
March 7th, 2012 09:41 AM #2
March 7th, 2012 09:52 AM #3
Boy, were you duped. Replace the clutch disc to solve a lurching problem? That mechanic was a blockhead.
Most likely you have a fuel or timing problem. Have your ignition wires looked at (easy) and checked for electrical leaks from cracked rubber parts first, as that's easiest to diagnose.
- Nov 2011
- 86
March 7th, 2012 03:00 PM #4oh no?!..
sa tita ko po ito. i told her to have the car check dahil nga ganon ang naramdaman ko. dinala ito ng pinsan ko sa mekaniko and said that the c.lining, c.plate and r.bearing needs to be replaced. di ko po alam na pinalitan na. recently, nagamit ko na ulit un oto and same problem occurs. T_T naman.
try ko po bumili ng high tension wire since parang mga mga kagat ng daga un. di na kase ito ginagamit dahil po nakabili kami ng medyo malaking sasakyan na madalas na gamitin ngayon.
check ko po ito bukas.
baka meron pa po kayong advise for this kind of problem.
task tom:
hi tension wire
fuel filter
air filter
- Nov 2011
- 86
March 9th, 2012 05:06 AM #5i already changed these today since due na din po ito this month, might as well palitan na din...
oil
oil filter
hi tension wire
fuel filter
air filter
but still yumayanig pa din pag nasa 2-3k RPM. any people with same issue?
pag idle naman sir ok ang makina.. kahit pigain un pedal walang problema..
kapag umaandar lang po ito nararamdaman.. nangangabayo!
di na po ako bumalik dun sa mekaniko and ask muna po ako dito mga sir para may "bala" in case
may maling sinasabi ang mekaniko.
(sa hirap ng buhay ngayon, posible na perahan tayo.)
- Nov 2011
- 86
March 10th, 2012 08:55 AM #6did replaced the air filter and now it good.... but not better...
meron pa din slight "kadyot"...
maya try ko palitan ang fuel filter.. sana ito na ang huling sagot sa problema..
Choosing one would depend on your driving and parking conditions. Do you have your own garage =...
MG4 EV Standard vs BYD Atto 3 Dynamic vs Toyota...
