Results 1 to 10 of 15
- Apr 2009
- 272
August 24th, 2016 12:57 AM #1Ive noticed some stiffness when i change gears especially if im on the road for like an hour already. But sometimes its really soft when its raining or if weather is cold. What could be the problem? 1997 Corolla gli 1.6 here.
- Jul 2016
- 1,178
August 24th, 2016 01:13 AM #2Baka clutch master yan sir. Ganyan din dati sa small body corolla ko. Palit lang ng clutch master. Tumino naman. Tnx
Sent from my SM-J500G using Tsikot Forums mobile app
August 24th, 2016 06:23 AM #3
- Apr 2009
- 272
- May 2016
- 80
October 18th, 2016 11:44 PM #5Same rin po ba if mahirap mag gear sa 1st gear lang? The 2nd to 5th to R swabe naman
Sent from my ASUS_T00J using Tsikot Forums mobile app
- Jun 2016
- 43
October 19th, 2016 11:17 AM #6
October 21st, 2016 01:06 PM #7
Have you replaced your tranny oil? What viscosity? Sounds like you need a tranny oil change (with the correct grade).
Case in point, Classic Mercedes Benz manual transmissions specify ATF (go ahead, google it ....). If the mechanic servicing it is clueless, then loads up on ordinary hypoid gear oil, the owner of the car will experience "maganit" shifting when first driving the car in the morning. As the transmission heats up and the oil thins out, normal shifting is experienced.
In your case, the tranny oil maybe good when cold, but thins way out when it heats up, thus you experiencing stiffness.
My 2 cents.
- Dec 2016
- 27
December 5th, 2016 05:56 PM #8Good pm. Tanong lang ako ho ako ng subok na shop cavite area, taga imus po ako. Gusto ko sana ipacheck at ipaayos kung anong sira sa clutch/transmission ng sasakyan ko, ang ganit(mahigpit) tapakan ng clutch/hard shifting especially 1st gear, kapag reverse dahil nga din siguro ang ganit tapakan ng clutch hindi ko gaanong natatapakan minsan kaya tumutunog/nabibitin pag kagat sa reverse. Last major pms 45k km ko was this year march, hindi natingnan yung clutch/tranny dahil hindi ko din naipacheck(1st time sa casa/walang pang alam.)
December 5th, 2016 09:45 PM #9
Hulaan natin sasakyan mo. Ito ba ay 2006 na toyota vios mt?
- Oct 2014
- 162
December 5th, 2016 10:41 PM #10
https://www.autoindustriya.com/auto-industry-news/nissan-confirms-van-partnership-with-mitsubishi-fo...
Mitsubishi Philippines
