Quote Originally Posted by baker123 View Post
ah yes. sorry sa tthreadstarter naging tps yung topic.
well 4jgtotsie. the TPS can be adjusted. just loosen the bolts that attaches it. put a voltmeter or multi-tester. move it and see the meter go up or down. then set to desired voltage. when close its 0.5V when WOT its 4.5V.
It can be adjusted, but what good will it do if the ECU is sending an in accurate voltage.
